7
When I was reading the nameplate of a small 5KVA generator, I found that the power factor is mentioned. It was 0.8 .
  1. Is this the minimum power factor that the generator can handle? or Is it the power factor that the generator should work at?
  2. I mean If I connected a load of 0.95 power factor. Is it better than a load of 0.8 power factor?
  3. If I would like to design a capacitor that corrects power factor. Should I correct the power factor of the load to be 0.8 or 1 ?
  4. Does the generator have an internal capacitor to correct power factor? so that when I connect a load of 0.8 power factor, The generator will see a power factor of 1.
Thank you very much,
It is the minimum power factor for full-load operation. It can probably handle a lower power factor with reduced load.
It is better in terms of reducing the losses in the generator, but it won't let you deliver more than rated watts.
Correcting to 0.8 would be good. Correcting higher might not provide much benefit.
A wound field synchronous generator will supply reactive current up to the capability of its excitation control system. That isn't quite the same thing as correcting the power factor and it doesn't involve an actual capacitor, but it does make the generator behave like it has an internal capacitor.
More about generator ratings
For an engine-generator set, the KVA rating is basically determined by the maximum current. The KW rating is determined by the power rating of the engine. A generator set rated 5 KVA, 0.8 pf, the engine would be capable of generating 4 KW. Operating at 5 KVA and 4 KW would be operating at the maximum capability of both the engine and generator. If the power is 4 KW but the pf is less than 0.8, the KVA would exceed the generator rating. If the generator is operating at 5 KVA and the pf is higher than 0.8, the KW would exceed the engine rating.
No matter how the relative ratings of the generator and engine are selected, there is only one pf at which the capabilities match. Somehow it has been determined that selecting 0.8 as the standard rating satisfies most customers in terms of buying neither an engine nor a generator that is larger than required.
  • \$\begingroup\$ Thank you very much for your useful answer. Would you tell me what do you mean by "it won't let you deliver more than rated watts" , Please? Does that mean that the generator will not produce more than 4 kw? because it is rated at 5KVA and power factor is 0.8? So, I think it is better to buy a generator that is rated at power factor of 1 , is not it? Thank you again, \$\endgroup\$ Apr 21, 2016 at 22:05
    \$\begingroup\$ You probably will not find an engine-generator set rated 1.0 pf. See the addition to my answer. \$\endgroup\$
    – user80875
    Apr 21, 2016 at 23:30
  • \$\begingroup\$ The generator is rated 5 KVA, representing the max apparent power that can be drawn. When p.f is 1, S = P. So if a load with a p.f of 1 and rated 5kW is connected to the generator, the generator should still be able to carry it, since the none of its limits have been violated; the engine still delivers the same 5kVA that it would deliver, if it were powering a 4kW load with a p.f of 0.8. Did i get anything wrong here? \$\endgroup\$ Apr 22, 2016 at 2:15
  • \$\begingroup\$ The generator can still carry the 5 KVA but the engine driving it must deliver 5 kW + losses rather than 4 kW + losses with a 0.8 pf. The generator is rated 0.8 pf because that is a more typical load and there is no reason to put on a larger engine when most loads don't need it. \$\endgroup\$
    – user80875
    Apr 22, 2016 at 2:26
