Source: LiPo Battery (13V - 16.8V)
Consumer #1: 5V (RaspPi) ~1A
Consumer #2: 12V (variouse) 0-3A (plus ~1A if series)
DC/DC step down: two LM2596
Which would be the better solution:
LM2596 #1 on LiPo (16.8V to 12V out)
LM2596 #2 on LiPo (16.8V to 5V out)
LM2596 #2 on LM2596 #1 (12V to 5V out)
What are the pros and cons in term of efficiency, and voltage stability?
Datasheet of the dc/dc converter,
Max output current is 3A .
The battery can provide a discharge rate of 35c at 10Ah
Efficiency diagram is on page 6.
Note: The 12V output might be used to supply 12V/3A to a battery charger (Yeah, charging a liPo with a liPo,.. thinks that happen in RC-hobby). So the drawn current on the 12V out could raise by 3A instantly. So yeah, right now I see the issue with the serial concept, I'd limit my charging current to 2A instead of 3A. But are there other pros and cons?
