I'm trying to find the expression that describes the auto-correlation of two heaviside functions u(t). I was told that the result must be 1/2, which makes total sense, as the power spectral density of the heaviside function must be a Dirac's delta centered in 0 with 1/2 area (which can be seen using the Fourier Transform).
This is how I thought it:
$$ r_{xx}(\tau) = <u(t+\tau) \cdot u(t)> = \lim_{T\to\infty} \frac{1}{2T} \int\limits_{-T}^{T} u(t+\tau) \cdot u(t) dt = \lim_{T\to\infty} \frac{1}{2T} \left( \int\limits_{0}^{T}dt + \int\limits_{\tau}^{T}dt \right) = \lim_{T\to\infty} \frac{1}{2T}(T+T-\tau) = \lim_{T\to\infty} \frac{1}{2T} (2T - \tau) = 1 - \lim_{T\to\infty} \frac{\tau}{2T} = 1 $$
What am I missing?
Thanks in advanced.
    \$\begingroup\$ This isn't specifically anything to do with electronics is it. There is a math SE site. \$\endgroup\$ – Andy aka Apr 22 '16 at 14:34
  • \$\begingroup\$ Might also be a good match for the DSP stackexchange. \$\endgroup\$ – JRE Apr 22 '16 at 15:10
@JRE has a good point - a better match for DSP. But in any case,
$$\int_{-T}^Tu(t+\tau)\cdot u(t)dt=\int_{-T}^{0}0dt+\int_{0}^T1dt=T$$ $$\lim_{T\to\infty}\frac{1}{2T}\int_{-T}^Tu(t+\tau)\cdot u(t)dt=\lim_{T \to \infty}\frac{T}{2T}=\frac{1}{2}$$
| improve this answer | |
I think a more correct demonstration would be $$ \int_{-T}^{T}u(t+\tau)\cdot u(t)dt=\int_{max(0,\tau)}^{T}dt=(T-max(0,\tau)) $$ which anyway leads to the same result because of the limit taken in \$T\$.
