I'm making a bench power supply, which will go from 0 to 17VDC and up to 30ADC at the output, which will have a voltage and current regulation (with potentiometers).
I am wondering, is it okay to use a push-button to short-circuit the Vcc and the GND pin, current going through the shunt resistor (enough for 30A or 50A)?
And the second part of this question here is, can I use (instead of 30A push button) a smaller push-button and few of MOSFET transistors, where I'd connect the current to the Emittor, some smaller voltage (I have stabilized +5 and +12VDC from the circuit) connect to the Base of MOSFET and the Colector to the shunt (where the other pin of shunt goes to GND)?
The thing (as I imagined) would work such as: I set the voltage, then I press the button. While the button is pressed, through the shunt goes max. current, as my circuit let's it through. While I'm measuring the current going through the shunt, I can regulate it and set it to desired value.
EDIT: Is okay to use shunt in series as this schematic applies?
