I have a circuit containing an atmega328p microcontroller with hc-05 bluetooth module. microcontroller is powered via 7805 regulator. When 7805 is supplied the source voltage by a 9V battery, the circuit works fine on a breadboard, but the same circuit fails on a PCB. I have tried two different PCB designs, but they have the same problem. The battery input voltage falls from 9V to less than 1V. I have verified multiple times that the PCB design is the same as the breadboard design. Is that a fundamental rule to PCB designing that i am missing?
    \$\begingroup\$ They are different instances of the circuit, so one could easily have a fault that the other doesn't. A PCB can easily slip a short-circuit through on you if you don't pay attention to what things touch the ground plane, beware metal tabs on ICs especially. \$\endgroup\$
    – Neil_UK
    Apr 23, 2016 at 8:32
  • \$\begingroup\$ 1V on battery suggests there is almost certainly. a major error. Check check rerere-check regulator Are you reversing polarity in the two designs. Note on TO220 tab is usually grounded on 7805. D o you have caps on Vin and Vout.? Oscilloscope says ? \$\endgroup\$
    – Russell McMahon
    Apr 23, 2016 at 11:23
NO.
Simple as that.
There are, however, differences. The breadbord is pretty bad, from an electrical engineering perspective. It adds stray inductance, capacitance and resistance everywhere. This usually makes your circuit worse. In this case, maybe by pure luck, the exact same design on the PCB oscillates because it now lacks the stray capacitance and inductance, but I wouldn't bet on it.
Oscillation in a circuit can make things draw much more power than expected, but you won't be able to verify this easily without an oscilloscope¹. Without an oscilloscope you have limited means to debug this issue.
If you power this with a battery, it sounds to me that you don't have a well-equipped lab, but you do have a multimeter. I don't know what you mean by "verified" that the PCB and breadboard are the same, but you should check for shorts with a multimeter, not just look at the PCB.
1. pun not guaranteed
