328
I've been trying to design a charging system for a small robot powered by a 2S 20C lithium polymer (LiPo) battery. Were I to trust everything I read online, I would believe that the LiPo will kill me in my sleep and steal my life savings. The common advice I read, if you are brave enough to use LiPo batteries, is "never leave unattended", "never charge on top of a flammable or conductive surface", and "never charge at a rate faster than 1 C".
I understand why this is prudent, but what is the actual risk with LiPo batteries?
Nearly every cell phone, both Android and iPhone alike, contains a LiPo battery, which most people, including myself, charge while unattended—often-times while left on a flammable or conductive surface. Yet you never hear about someone bursting into flames because their cell phone exploded. Yes, I know there are freak accidents, but how dangerous are modern LiPo batteries? Why do so many online commenters treat stand-alone LiPo batteries like bombs waiting to go off, but don't even think twice about the LiPo sitting in their pocket?
  • 4
    \$\begingroup\$ Good design means that most of the time they don't cause fireballs. Most of the time. youtube.com/results?search_query=lipo+battery \$\endgroup\$ – user65586 Apr 24 '16 at 1:55
  • 12
    \$\begingroup\$ See this and this; the basic jist is that what makes a "Li-Po" battery work is similar technology as a lithium-ion battery, and as such they can fail catastrophically because the internal components are highly reactive with each other, and it's relatively easy to damage them because we care about things like power density, weight, and price. That being said, it's not too easy to damage them if you're careful with the design, and don't physically try to abuse the cell. \$\endgroup\$ – helloworld922 Apr 24 '16 at 2:10
    \$\begingroup\$ Safety Concerns with Li-ion. Technical summary of lithium battery failure mechanisms: Lithium Battery Failures. \$\endgroup\$ – Nick Alexeev Apr 24 '16 at 14:47
  • 7
    \$\begingroup\$ All the answers seem to address fire and explosion possibilities, but they can vent some pretty nasty gas, too, which can cause permanent lung damage \$\endgroup\$ – Scott Seidman Apr 25 '16 at 16:41
  • 83
    \$\begingroup\$ Oh wait, Po is not the chemical symbol. That's a relief. \$\endgroup\$ – Mr Lister Apr 25 '16 at 21:23
657
+200
Every cell phone (as well as laptop and nearly everything with a rechargeable battery) uses LiIon/LiPo (essentially equivalent for the purposes of this discussion). And you're right: In terms of actual incidences, lithium-ion and lithium-polymer are the safest battery chemistry to be in wide use, bar none.
And the only reason this now ubiquitous chemistry hasn't murdered you and/or your family several times over is that these cells aren't charged unattended. You may not be attending it personally, but every single one of those lithium-ion batteries has a significant amount of protection and monitoring circuitry that is permanently integrated into the pack. It acts as the gatekeeper. It monitors every cell in a battery.
  • It disconnects the output terminals and prevents them from being overcharged.
  • It disconnects the output if they are discharged at too high a current.
  • It disconnects the output if it is CHARGED at too high a current.
  • If any of the cells are going bad, the output is disconnected.
  • If any cell gets too hot, it disconnects the output.
  • If anyone of the cells is over-discharged, it disconnects the output (and permanently - if you forget to charge a lithium-ion battery for too long, you will find that it will no longer charge. It is effectively destroyed, and the protection circuit will not permit you to charge the cells).
Indeed, every single phone battery, laptop battery, *whatever battery that is a rechargeable lithium chemistry is the most closely monitored, scrutinized, and actively managed, the diametric opposite of 'unattended' as one can get for a battery.
And the reason so much extra trouble is done is because lithium-ion batteries are actually that dangerous. They need protection circuitry to be safe, and they are not even remotely safe without it. Other chemistries such is NiMH or NiCad can be used relatively safely as bare cells, without any monitoring. If they get too hot, they can vent (which has happened to me personally), and it can be pretty startling, but it isn't going to burn down your house or land you an extended stay in a burn unit. Lithium-ion batteries will do both, and that's pretty much the only outcome. Ironically, lithium-ion batteries have become the safest packaged battery by being the most dangerous battery chemistry.
You might be wondering what actually makes them so dangerous.
Other battery chemistries, such as lead-acid or NiMH or NiCad, are not pressurized at room temperature, though heat does generate some internal pressure. They also have aqueous, non-flammable electrolytes. They store energy in the form of a relatively slow oxidation/reduction reaction, one whose rate of energy release is too low to, say, cause them to eject 6-foot jets of flame. Or any flame, really.
Lithium-ion batteries are fundamentally different. They store energy like a spring. That's not a metaphor. Well, like two springs. Lithium ions are forced between the atoms of covalently-bonded anode material, pushing them apart and 'stretching' the bonds, storing energy. This process is called intercalation. Upon discharge, the lithium ions move out of the anode and into the cathode. This is very much electromechanical, and both the anode and cathode experience significant mechanical strain from this.
In fact, both anode and cathode alternatively increase or decrease in physical volume depending on the battery's state of charge. This change in volume is uneven however, so a fully charged lithium-ion battery is actually exerting nontrivial amounts of pressure on its container or other parts of itself. Lithium-ion batteries are generally under a lot of internal pressure, unlike other chemistries.
The other problem is their electrolyte is a volatile, extremely flammable solvent that will burn quite vigorously and easily.
The complex chemistry of lithium-ion cells is not even completely understood, and there are a few different chemistries with different levels of reactivity and inherent danger, but the ones with high energy density all can undergo thermal runaway. Basically, if they get too hot, lithium ions will begin reacting with oxygen stored as metal oxides in the cathode and release even more heat, which accelerates the reaction further.
What inevitably results is a battery that self-ignites, sprays its highly flammable solvent electrolyte out of itself, and promptly ignites that as well, now that a fresh supply of oxygen is available. That's just bonus fire however, there is still a ton of fire from the lithium metal oxidizing with the ample store of oxygen inside.
If they get too hot that happens. If they are overcharged, they become unstable and mechanical shock can make them go off like a grenade. If they are over-discharged, some of the metal in the cathode undergoes an irreversible chemical reaction and will form metallic shunts. These shunts will be invisible, until charging expands part of the battery enough that the separating membrane is punctured by one of these shunts, creating a dead short, which of course results in fire, etc.: The lithium-ion failure mode we know and love.
So, just to be clear, not only is overcharging dangerous, but so is over-discharging, and the battery will wait until you've pumped a ton of energy back into it before spectacularly failing on you, and without any warning or measurable signs.
That covers consumer batteries. All this protection circuitry is less able to mitigate the danger of high drain applications, however. High drain generates no small amount of heat (which is bad) and more worrying, it causes huge amounts of mechanical stress on the anode and cathode. Fissures can form and widen, leading to instability if you're unlucky, or just a shorter useful life if it is not too severe. This is why you see LiPos rated in 'C', or how quickly they can be safely discharged. Please, take those ratings seriously and derate it, both for safety and because many manufacturers simply lie about the C rating of their batteries.
Even with all that, sometimes an RC Lipo will just burst into flame for no reason. You absolutely need to heed the warnings to never charge them unattended, and everything else. You should buy a safety bag to charge them in because it might prevent your house from burning down (possibly with you or loved ones inside). Even if the risk is very low, the damage it can cause is vast, and the measures needed to mitigate most of that potential for damage are trivial.
Don't ignore everything you're being told - it's all spot on. It comes from people who have learned to respect LiPos for what they are, and you should too. The thing you definitely want to avoid is having this lesson taught to you by a lithium-ion battery, instead of peers online and offline. The latter might flame you on a forum, but the former will literally flame you.
Let's see some videos of stuff exploding!
Let me go a little more into how they fail. I've discussed the mechanism, but what really happens? Lithium-ion batteries really only have one failure mode, which is kind of exploding then shooting out a stunningly huge amount of fire in a giant jet of flame for several seconds, and then continuing general burning-related activities for a bit after that. This is a chemical fire, so you cannot extinguish it (lithium-ion batteries will still shoot out huge jets of fire even in the vacuum of space. The oxidizer is contained inside, it doesn't need air or oxygen to burn). Oh, and throwing water on lithium does nothing good, at least in terms of fire reduction.
Here is a 'greatest hits' list of some good examples of failure. Note that this does sometimes happen in high drain RC cases even with proper safety measures in place. Comparing high drain applications to the much safer and lower currents of phones is not at all a valid one. Hundreds of amperes ≠ a few hundred milliamperes.
RC plane failure.
Knife stabs smartphone-sized battery.
Overcharged LiPo spontaneously explodes.
Laptop battery in a thermal runaway is lightly pressed on, making it explode.
  • 91
    \$\begingroup\$ This is a great answer. Wish I could upvote it twice. \$\endgroup\$ – Adam Haun Apr 24 '16 at 3:57
  • 19
    \$\begingroup\$ Apparently, the correct thing to do when faced with a battery explosion/fire is to stick your head directly into it immediately afterwards, like the guy on the first video... \$\endgroup\$ – JBentley Apr 24 '16 at 17:42
  • 11
    \$\begingroup\$ Now I am terrified of batteries. (Also I think that its funny that it has only one failure mode, even in space.) \$\endgroup\$ – PyRulez Apr 25 '16 at 3:16
  • 12
    \$\begingroup\$ @Aron: In theory and practice RC batteries have ZERO protection circuits to them. I'd like to point out that there's a huge difference between RC batteries and toy batteries for RC toys (which do have protection). The RC hobby industry (as opposed to the toy industry) have assumed that protection belongs to external circuits like your battery charger and ESC. Even then, the majority of hobby-grade battery charger basically allows you (requires?) to configure the "protection" by setting the max current supplied. They don't have sensors to automatically sense that the settings are wrong. \$\endgroup\$ – slebetman Apr 25 '16 at 9:01
  • 36
    \$\begingroup\$ @AdamHaun It's a safety precaution built into StackExchange in order to prevent it from spontaneously exploding from overupvoting... \$\endgroup\$ – Pavel Apr 27 '16 at 13:53
80
To use Lipo batteries safely, you must treat them with the same respect you would anything that can store and rapidly release a large amount of chemical and/or electrical energy. The bigger the battery and the lower the internal resistance (e.g. higher C rating) the more you need to be careful. They can be used safely... just like gasoline can be used safely but to do so you must learn about how they operate and how they can fail.
When you think about it, it's no surprise that, for instance, a Tesla battery has about the same level of risk as the gas tank it replaces... they both store a lot of energy that can be released rapidly when needed. Well actually, I lie somewhat because a Tesla battery only holds the energy of a tiny gas/petrol tank and it's got more safety checks built into it.
I have safely used large Lipo batteries in high performance R/C airplanes and helicopters (up to 90C batteries) for about 15 years (I was an early adopter.) Besides my own experience I have that of others in my clubs. I've seen packs fail in the past, but it's really rare now, because we've learned to use them with respect. Here's what I learned living life on the edge. :)
Failure modes
The most common failure modes are:
  • physical damage (this causes them to short out internally)
  • over charging (caused by faulty/bad charger)
  • over heating due to high discharge current (causes puffed pack or worse if the heat is really high)
The least common modes of failure I've heard of (but never witnessed) are:
  • spontaneous cell failure due to shoddy manufacturing that caused internal short (usually aggravated by physical shock but not always)
All failure modes list above can result in "vent with smoke" or "vent with flames". Newer lipos with less volatile electrolytes can "vent with smoke" but you can never be sure; so you have to plan for the worse case.
Standard Operating Procedure (SOP)
Here is the minimal standard operating procedure (SOP) for using a high discharge (any R/C pack is high discharge) bare lipo packs that I use:
Physical Protection
  • cells must be protected from physical damage
  • if your environment is rough, consider an R/C car hard pack (carbon fiber case around soft Lipos)
  • cells must be inspected for physical damage before and after each use
  • if any cell is physically damaged in any way, they should be moved to a fire safe area and then slowly (1C) discharged down to 2 volts per cell or less, and then safely disposed of (no damaged cell should ever be considered safe again)
  • do NOT transport damaged cells; treat them with the same respect you'd treat a firework whose wick you aren't sure is out yet and that could still go off at any time!
By the way, unlike what @metacolin wrote, it IS safe to discharge a Lipo to a low voltage and is the preferred thing to do before disposing of a pack. You want to remove all chemical energy from a pack to make it safe. What isn't safe is to discharge a cell below 2V and then to charge it. Charging a low voltage cell can cause Lithium to plate out making the cell unstable.
Charging (this is the most critical time for safety)
  • do this away from anything flammable and that wouldn't suffer smoke damage (e.g. outside)
  • always ensure that each cell is being individually monitored during charging; a quality R/C charger with "balanced" charging will do this
  • check cell voltages before charging (a quality R/C charger will do this automatically), if any cell is below 3V, treat the pack with suspicion and balance charge it slowly to see if recovers
  • if any cell voltage is below 2V don't charge (a quality charger will do this automatically); discharge the other cells and then safely dispose of the pack... once a cell goes below 2V, it's not safe to charge any more because lithium metal can plate out and make the cell unstable during subsequent charging
  • don't use a low end charger that does have good voltage calibration
Discharging
  • rapid discharging that builds up too much heat is a problem; see Heat discussion below
  • over discharging is safe... once; but don't ever charge again; see Charging discussion above
Heat
  • ensure cells never get hot (due to rapid discharge, rapid charge, sitting in sun, etc.) 45 Celsius is the absolute maximum that I tolerate... but under 35 Celsius is much better
  • don't discharge or charge cells that are too cold; warm them up first... cells work best from about 10 Celsius to 30 Celsius; lithium plating can again be a problem if they are used when they are too cold
Long life
  • if you want your cells to last a long time (calendar) it's best to follow the 80/20 rule with Lipo batteries; that is don't discharge them below 20% capacity or above 80% capacity; this is what modern battery management systems (BMS) do (e.g. Tesla, iPhone, etc.)
  • when batteries are in storage for more than a week, ensure they are balanced charged to about 60% capacity per cell (again, a good R/C charger can do this automatically for you.)
Final thoughts about your question
So, yes, if you develop safe SOPs and take actions to mitigate risk you could use a Lipo in your robot. Until you fully understand safe SOPs, I wouldn't even consider making your own charger or BMS. Smart people have spent years stuff like that.
Otherwise, depending on your design needs, maybe a simple NiMh, SLA battery could meet your needs. However, even NiMh and SLA batteries they have their own SOPs to follow. For instance, NiMh cells can blow up due to pressure during charging if they are overcharged and their pressure valve fails. SLA's generate hydrogen gas! during charging... so they need to be well vented.
Remember everything useful can also be dangerous. Lipo's are no worse than a chef knife, or a airplane wing full of kerosene. The trick is to learn how to use them all wisely.
Edit: Confronting misinformation
Myth 1
@metacollin, writes that Lipo "anode and cathode experience significant mechanical strain"
False ... Lithium Polymer cells are not under any significant stress during normal operation. This is why they can be packed in plastic pouches.
But don't take my word for it. Watch this expert say it at 10:00. (Spoiler alert: he calls the affect "benign".)
https://www.youtube.com/watch?v=pxP0Cu00sZs
P.S. I highly recommend watching the whole video if you want information from and expert (rather than somebody on here that pretends to be an expert.)
NiMh or NiCd chemistry are in fact more dangerous in regards to strain/pressure build up. Both can generate excess oxygen if they are overcharged. This is one reason why NiMh and NiCd cells are contained in round metal cans with safety vents and not plastic containers like LiPo's. Read this spec. sheet for a full explanation:
http://data.energizer.com/PDFs/nickelmetalhydride_appman.pdf
Myth 2
@metacollin, "They need protection circuitry to be safe, and they are not even remotely safe without it."
True. However, what is important is that the complete system of batteries and charging work together to keep all the cells of a battery operating withing spec. There is more than one way (topology) for this to be done:
  1. Include a "protection" circuit per cell and don't rely on the charger or user to be within spec. The "protection" circuit does these things:
    • turn off cell (open circuit) if current goes too high
    • turn off cell if voltage goes too low
    • turn off cell if voltage goes too high
Because cell mounted "protection" circuits can only be of limited size, they generally are only good for low current scenarios.
  1. Alternately you can use bare cells as long as you always use them with a smart balanced charger that:
    • refuses to charge if voltage is too low
    • ensures charge voltage never goes too high
If you desire fusing, you can place an appropriate fuse inline with pack.
This is what R/C users do because they want batteries to be as light as possible and able to deliver high current.
  1. The ultimate strategy is to use bare cells wired into a more complete battery management system (BMS). BMS's can have many different topologies based on what parameters you are optimizing for. BMS's can also do other non-safety related things like adding features (e.g. a state of charge gauge) and trying to increase the lifespan of the battery by controlling operating parameters. Modern electric cars and electric bikes use BMS's (and not "protected" cells.) Additionally, modern consumer electronics with built-in LiPo's have switched away from using protected cells to using BMS's. E.g. iPhones, iPods, etc.
From a safety aspect, all these setups do the same thing as a complete system. They just do it in different ways because they are optimized to different parameters.
  • \$\begingroup\$ You mean you wouldn't even consider making your own charger or BMS, right? \$\endgroup\$ – user253751 Apr 25 '16 at 1:51
    \$\begingroup\$ @MichaelKjörling re your first question: "moving": short way to the next fire safe area - "transportation": anything longer, involving cars, trains,... \$\endgroup\$ – guntbert May 1 '16 at 18:08
  • \$\begingroup\$ Would charging a battery that is still warm to the touch from usage (a single cell LiPo of a small rc helicopter) for one minute before disconnecting the battery from the charger be problematic for e.g. lifespan and safety (I did exactly that once by mistake)? \$\endgroup\$ – Aqqqq Nov 16 '20 at 21:57
54
When a big company wants to make a LiPo charger, they can:
A. Have experts on staff and do extensive testing to make sure the charger will work safely across the full range of operating conditions.
B. Buy pre-made ICs or assemblies that have been given that same level of care.
C. Subcontract out the work to people who know what they're doing.
When you build a charging circuit at home, you don't do any of those things.
LiPo batteries can definitely burst into flame, as a YouTube search can tell you. You'll find people actively destroying the batteries with nails or even an axe, but you can also find more realistic examples, like this one of an RC aircraft violently bursting into flame due to a charging problem.
Hence the warnings -- people on the internet can't guarantee that a homemade charging circuit will always work safely, and the failure mode of LiPo is "bomb". That's what a bomb is, after all -- lots of energy being released quickly.
  • 8
    \$\begingroup\$ Another factor is that Li-Ion cells of all types can catch fire even if you dot all your Is and cross all your Ts when it comes to protection -- internal cell defects suck. \$\endgroup\$ – ThreePhaseEel Apr 24 '16 at 3:22
  • 5
    \$\begingroup\$ Worth mentioning is that they can A, B, C, and still fail to make it right the first time (e.g. Boeing/Thales/Yuasa). \$\endgroup\$ – Eugene Ryabtsev Apr 25 '16 at 4:43
    \$\begingroup\$ This answer deserves more love as it's not covered by the most voted one above - the likes of Apple & Samsung have a billion dollars to lose if their products start immolating customers, random eBay sellers from China turning out fake batteries, chargers, and other products have very little to lose. I'm very wary of doing projects with homebrew LiPo setups simply because I know that I don't know enough to be sure it's safe, and with a sample of 1 battery pack you can never really know if you've got it right - and even if it burns your house down, did you get it wrong or was it a rogue battery? \$\endgroup\$ – John U Apr 25 '16 at 10:48
    \$\begingroup\$ You imply that commercial LiPo chargers should be safe because big companies make them. I'd expect that the charging circuit in a name-brand mobile phone would be OK, but I'd take a bit more convincing that the charger that comes with a cheap toy quadcopter, say, was any better than what I could design. You only have to read a few questions on here to find examples of terrible circuit designs in commercial products. \$\endgroup\$ – nekomatic Apr 27 '16 at 15:36
    \$\begingroup\$ @nekomatic Very true. Commercial does not imply high-quality. Quality comes from doing A, B, and/or C, not from being a big company. The OP specifically asked about Apple and Android phones, so that's what I was thinking of when I wrote my answer. \$\endgroup\$ – Adam Haun Apr 27 '16 at 16:24
40
[Though this late answer may get little exposure now that the question has exited the hot-list, I think it is essential to further emphasize the contrast between the comprehensive safety features in devices such as laptops and cellphones vs. the typically far less comprehensive safety features in hobbyist or DIY devices.]
Context is essential when evaluating those dire safety warnings that you cite. They are not targeted at devices like laptops and cellphones (from reputable manufacturers) that employ tightly integrated battery management / protection circuitry to keep them safe. Rather, they target less safe devices, e.g. unprotected LiPo cells used in RC hobbies to power Remote-Controlled cars, planes, etc. Below we take a much deeper look at these differences in safety.
Unlike other battery chemistries familiar to consumers, batteries based on Li-ion chemistry are inherently much more volatile. Due to such, they require very carefully designed battery management circuitry to protect them from catastrophic failure. This includes mechanisms that prevent them from reaching dangerous states (under or overcharge, over-temperature, over-current, etc) and, further, may disable them when dangerous conditions arise (e.g. via a FET, PTC or one-shot fuse). Such logic may even include sophisticated algorithms that continuously monitor the health of the cells in order predict impending serious failures (such as an internal short, which can lead to thermal runaway).
Unlike most user-assembled hobby / DIY devices, for laptops and cellphones the manufacturer has design control of the entire battery power subsystem, therefore they can design a very tightly integrated system including sophisticated fault tolerant protection mechanisms. Such designs follow time-tested industry standards and employ multiple levels of redundancy and comprehensive failure analysis methods, e.g. fault-tree analysis or FMEA = failure modes and effects analysis.
You may be surprised by the comprehensiveness of such analyses, e.g. below are 2 of 96 cases considered in IEEE 1625 2004, including the case that a pet urinates on the device (a PC). enter image description here
You may also be surprised by the high level of redundancy of fault protection employed, e.g. according to said industry standard, laptop batteries must implement at least two independent methods to turn off the charge FET to prevent catastrophic overcharging. Furthermore, if both methods fail, then a fail-safe chemical fuse must blow. This is a special voltage-triggered 3-terminal fuse that can function even under extreme conditions such as when the battery voltage drops extremely low due to a short-circuit.
Contrast the above to your DIY project or RC hobbies where the end user is responsible for integrating the components of the battery subsystem and ensuring that they function together safely (the components being the cells, BMS/PCM protection board, device, and charger). There are many obstacles hindering such. The user may lack sufficient knowledge. The user may lack access to datasheets and technical information, which is generally not made available to consumers (cell manufacturers strongly discourage direct consumer use, e.g. recently Sony sent a cease and desist order to a NYC vaping store selling Sony 18650 cells - see below). Lack of standard communication protocols such as SBS = Smart Battery System in the RC / hobby world limits the communication between subsystems, which greatly increases the difficulty of designing sophisticated safety mechanisms such as those in laptops.
Here is a real-word example: a question from TI's battery gas gauge support forum.
I am wondering if these Chemical Fuses are a mandatory element of Lithium-ion battery packs. I am working with a Chinese Li-ion pack supplier, and they produced a pack design based on a bq20z45-R1 fuel gauge IC, but there was no Chemical Fuse circuit. Also, there was no secondary-overvoltage-protection IC such as the bq29412. Are the Chemical Fuse and bq29412 (or similar IC) required for commercial Li-ion battery pack applications? Is there a Regulatory requirement? BTW, I am working on a medical device design.
Above we have an example of a battery pack which lacks the 2nd and 3rd level of overcharge protection described above. Such omissions of safety features are common on many cheaper battery management systems. Not to mention some fly-by-night Chinese manufacturers who greatly exaggerate the level of protection implemented. In order to recognize such omissions and to comprehend their ramifications, when the end user is the engineer, they must have adequate background knowledge in the field. Lacking such could lead to designs with serious safety defects. That's why reputable cell manufacturers such as LG, Panasonic, Samsung, Sanyo and Sony refuse to deal directly with consumers. The risks are far too great if one does not have adequate knowledge to ensure safe design.
Below is the Sony letter mentioned above. This is typical of the attitude of reputable cell manufacturers concerning the serious safety risks posed by consumer use of loose cells. enter image description here
For convenience, below are the links given in the letter:
Electronics Cigarette Fires and Explosions, U.S. Fire Administration, FEMA, OCtober 2014
Battery Safety, Consumer Technology Association.
  • \$\begingroup\$ Would charging a battery that is still warm to the touch from usage (a single cell LiPo of a small rc helicopter) for one minute before disconnecting the battery from the charger be problematic for e.g. lifespan and safety (I did exactly that once by mistake)? \$\endgroup\$ – Aqqqq Nov 16 '20 at 21:59
    \$\begingroup\$ @Aqqqq Likely very little if any. But if you did that very many times it may have cumulative effects that might add up to nontrivial degradation. Generally the more time the battery spends at extreme voltages and temperates the more this accelerates (exponential!) internal degradation processes, so the more you can aboiv such the better for longevity. \$\endgroup\$ – Bill Dubuque Nov 16 '20 at 22:10
    \$\begingroup\$ @Aqqqq See these slides for a nice summary of the primary deradation processes in Li-ion batteries. \$\endgroup\$ – Bill Dubuque Nov 16 '20 at 22:10
All great answers. Here is a short one. A 7.4 volt. 5 amp-hour battery has 37 watt-hours of energy, or 133,200 joules. Compare to a .357 Magnum's 873 joules of muzzle energy. The trick is not to let it a bunch of it out at once by overheating or crushing.
  • \$\begingroup\$ One other "trick" is also not to, in an attempt to protect the customer from a "Roman Candle" firework, place the battery in a sealed "robust" container, and accidentally make a firecracker, or even a grenade! Be sure not to seal the vent holes, or block them, and be sure that each level of containment does not compromise venting for a worse result. Each container from top to bottom down to the battery needs to be able to vent! If you are a manufacturer, you should probably be testing what happens when a battery goes off in your product. \$\endgroup\$ – MicroservicesOnDDD Feb 14 at 2:12
I think your info is outdated.
I had a coworker who was into RC airplanes. They were early adopters of LiIon technology because they are light and hold a lot of power.
He related how they had two failure modes, one of which was incindiary. Planes would literally explode in a ball of fire while in flight.
Eventual commercial cells have, I later read, multiple different safety features integrated into the sellable units, required by law.
They are safe now, as long as you don't break or breach one, or allow it to get too hot. Heat control is part of the finished device design: you might have poor venting or improper thermal fusing and thus allow it to go critical. Some newer products are not quite so safe, in particular "bag cells" that don't have the durability to handle without being integrated in a properly designed device.
So, learn how to use them safely, and learn the specific details of the parts you choose for your design.
    \$\begingroup\$ 3 years on. I'd say that's only "more or less true, quite often". With LiIon things can go wrong quite spectacularly if abused, and MAY do so if not obviously abused. Bad designed batches don't help :-). || I've only had one "vent with flame" incident - and it was due to gross abuse. An old netbook with 0 battery capacity was left on chg for days. With a good battery it would have been fine. After some days it erupted in flame & smoke. It was sitting on a sofa (couch) BUT fortunately there were several layers of glossy cardboard which took most of the flame. It went outside very rapidly :-). \$\endgroup\$ – Russell McMahon Jun 12 '19 at 11:29
  • \$\begingroup\$ @Aqqqq that sounds like a new Question. How about posting it as such? You could reference this Q/A as being relevant but not an answer. Posting a new question in a comment to an old question will only be noticed by a small number of people, and not answered as this is not the place to ask questions. \$\endgroup\$ – JDługosz Nov 17 '20 at 17:54
  • \$\begingroup\$ I see you posted the identical question as a comment just above, too. That's not good, here. \$\endgroup\$ – JDługosz Nov 17 '20 at 17:57
