I am working on a binary calculator using 2n3904 NPN transistors. I noticed when using a NOT gate the voltage gets divided when running the ouput of the NOT gate to a 10K resistor that controls the base pin of another transistor. Is there any way to avoid this?
    \$\begingroup\$ We love schematics. Much better than words. There's a schematic button on the editor toolbar. It's really easy to use. Welcome to EE.SE. \$\endgroup\$
    – Transistor
    Apr 24, 2016 at 17:41
  • \$\begingroup\$ A full circuit would be usefull. This site has an integrated circuit editor which should be a dequate for this kind of circuit. \$\endgroup\$ Apr 24, 2016 at 17:41
  • \$\begingroup\$ Can I edit my post \$\endgroup\$ Apr 24, 2016 at 17:45
  • \$\begingroup\$ @user3657511 Yes, you can edit your post by clicking the "edit" text below the post. Additionally, the post editor has a built-in schematic editor which can be accessed by clicking the {} button at the top of the editor. \$\endgroup\$
    – uint128_t
    Apr 24, 2016 at 17:48
Because R4 is connected to the base of Q2 -- when Q1 is off, it forms a load on Q1's collector (R1), so the voltage there won't rise above about 6 V.
This doesn't really affect the performance of the NOT gate -- its threshold is about 0.8 V, so any input higher than this will be a '1'.
Given that the transistors have a beta (gain) of well over 50, you don't need to use 10k -- you could use (say) 100k. This would allow the '1' voltage to rise to (approximately) 9V*100k/(100k+4.7k) = 8.6 V
