I've imported a 3D model of an enclosure and I want to check if my PCB will fit inside the box but I can't "open" the box inside Altium. How can I explode or take a 3D model apart in Altium?
    \$\begingroup\$ Typically I do it the other way around. I export my board to my CAD software. \$\endgroup\$
    – Axis
    Apr 27, 2016 at 9:29
You would be much better off using a tool like SolidWorks or SolidEdge to do your mechanical work. Altium is not designed to handle enclosures. You would export your board from Altium as a STEP model and open it in the mechanical CAD software. If you use SolidWorks, you would use the built-in tools to separate the pieces of the step model, and you would put your board STEP model into it. You should not be doing this in Altium.
You will have to create two bodys for your enclousure. One should be the enclousure itself, the other one being the lid of such a enclousure.
Now you match your PCB inside the enclousure and then place the lid over it. Thats the only way that I'm aware of doing such thing in Altium.
