I have a question regarding a control loop system which is subject to disturbance, unfortunately I missed a couple of lectures on the subject and now am scratching my head as to how to do it. The loop is shown below.
\$D(s)=\frac{K}{s+10},\$ \$M_p(s)=\frac{M_o}{s},\$ \$G(s)=\frac{s+3}{s^2+4s+5},\$ \$I(s)=\frac{1}{s}\$
\$K_t\$ isn't used for now so that can be ignored. \$M_p\$ is a step input disturbance.
Anyway, the question in hand is asking for the steady state error assuming the system to be stable, and I am simply struggling with getting the initial T.F. in order to get this.
It is given that I need to determine \$\frac{\theta(s)}{M_p(s)}\$ and furthermore am given that this is: $$\frac{(s+3)(s+10)}{s(s+10)(s^2+4s+5)+K(s+3)}$$
But I baffled as to how to get to this result, any ideas?
After this I know what to do but I just want to know how to get to this stage in the first place.
    \$\begingroup\$ Forward path is G(s)I(s), feedback path is D(s). Assume \$\theta_{ref}=0\$. To see this, re-draw the block diagram with the input signal of interest, \$M_p\$, on the left. \$\endgroup\$
    – Chu
    Apr 28, 2016 at 9:31
  • \$\begingroup\$ \$\theta=G\cdot I(M_p+D\cdot (\theta_{ref}-\theta ))\$, can you take it from here? \$\endgroup\$ Apr 28, 2016 at 9:55
  • \$\begingroup\$ @VladimirCravero Yeah I can get that I struggle to get \$\frac{\theta}{M_p}\$ on its own though... \$\endgroup\$
    – MrPhooky
    Apr 28, 2016 at 10:10
    \$\begingroup\$ Hint 2: \$\theta\cdot(1+D\cdot G\cdot I)=M_p\cdot G\cdot I\$, using \$\theta_{ref}=0\$. If you can't get it from here you need to exercise on algebra, not control systems. \$\endgroup\$ Apr 28, 2016 at 10:20
  • \$\begingroup\$ Then plug in all the other formula! \$\endgroup\$
    Apr 28, 2016 at 10:24
Just redraw the diagram like this: -
I've used Y instead of theta for my own convenience.
You get Y = I.G(M - Y.D) which reduces to \$\dfrac{Y}{M} = \dfrac{1}{\frac{1}{G.I} + D}\$
I can see that if you plug the expressions for G, I and D in you get the correct answer.
