I have read recently that frequent top-off charging of my personal electronics is hard on the batteries. Specifically, Li-ion batteries in recent model smart phones and laptops will show significant loss of capacity after (very roughly) 300 cycles between the remaining charge levels of 90% and 100%.
Below is a 'cartoon' of a plot to help clarify my question. Is cycling between the 90% and 100% points 'harder' on these types of batteries than an equal number of cycles between the 40% and 90% levels?
By 'harder' I mean a significant loss in battery capacity after (very roughly) 300 cycles, versus maybe 3,000 cycles.
Also, is cycling through the lower end (say 5% to 40%) also 'harder' than in the mid-range?
I'm not looking for opinions or best guess - I need a fairly clear answer with a link to further reading, and ideally an actual plot of this phenomenon - model or data.
edit: assume the charging is managed by the built-in electronics according to manufacturer's specifications.
NOTE: This question requires an engineering answer, but let's assume I am not so much of an engineer (anymore) that I have actually taken my phone and laptop apart and I'm hooking up volt meters to the individual cells!!!
Please assume I am simply either plugging into a power source, or not plugging into a power source, the way most people do, based on the 0-100% scale that my personal consumer electronic device displays.
Thanks!
cartoon battery cycling
    \$\begingroup\$ I'm not going to put forward a well researched answer, just enough comment so you can google for the relevant things. It's not charging through the top 10% that does the damage, it's the length of time spent warm above 4.1v, where lithium starts to go walkies. That's why chargers don't continue to trickle charge like you can with lead or nickel chemistries, they stop charging to allow the voltage to fall and spend most of its time below 4v. \$\endgroup\$
    – Neil_UK
    Apr 30, 2016 at 9:09
  • \$\begingroup\$ @Neil_UK thanks for the helpful info - 1st I have to change the title, 'through' is an unfortunate choice of words. Also, implicit in my question (which I'll also edit to make explicit) is the assumption that the charging is well managed by the associated electronics as recommended by each battery manufacturer. I just don't know how to say 'top off charge' in engineering-speak. \$\endgroup\$
    – uhoh
    Apr 30, 2016 at 9:16
  • \$\begingroup\$ See batteryuniversity.com | Here is your definitive answer :-) : Topping at 90% is fine IF you do it properly. | NEVER apply more than 4.2V, Charge at Imax until 4.2V reached. Imax is usually C/1 but see data sheet. | At Vbat = 4.2V swap to CV (constant V charging). Ichg will taper down under battery control. Stopping at Ichg = Imax/2 will give you the large majority of capacity. | Stopping at Imax/4 gives more capacity and more stress. | Stopping at Imax/10 is for road warriors and beats the stuffing out of your battery. | Reducing Imax to say 4.1V increases battery cycle life. .... \$\endgroup\$
    – Russell McMahon
    Apr 30, 2016 at 12:51
  • \$\begingroup\$ Stopping at Imax/2 improves cycle life. || NEVER NEVER NEVER trickle charge once end of charge cycle is reached. \$\endgroup\$
    – Russell McMahon
    Apr 30, 2016 at 12:52
    \$\begingroup\$ @uhoh I think you will increase your chances of obtaining a useful answer if - instead of posing the problem in the abstract - you add some background motivation that explains how you plan to apply this information. \$\endgroup\$ Apr 30, 2016 at 14:05
Yes, fully charging and discharging the battery will result in lower lifespan. The difference is not 10 times, but it is significant.
Here are some example plots from Kokam. For the 80% and 20% tests every 50th cycle was done at 100% (the vertical red lines) to check the full capacity.
At 100% charge/discharge the capacity dropped to 97% after 300 cycles.
At 80% it took over 1500 cycles. This is 5 times more cycles, but closer to 4 times improvement since only 80% capacity was available per cycle.
At 20% it managed 3000 cycles. This sounds impressive, but since only 20% of the full capacity was extracted it is equivalent to far fewer than 3000 full charge/discharge cycles. Depending on how the device being powered uses the available voltage and capacity, it may even be worse than cycling to 80%.
The main reason that a Lithium-ion battery 'wears out' is stress caused by expansion and contraction of the active material as lithium ions are squeezed in and out. Limiting the amount of charge/discharge reduces the expansion/contraction amplitude, which lessens damage to the plate material.
However, even if a lithium-ion battery is held at constant state of charge the plates will still degrade due to oxidation. This occurs faster at higher temperature and voltage, so keeping your battery cool and at less than full charge will increase its shelf life.
For a device such as a laptop which is usually used on mains power, it is better to run the battery down a bit and (if possible) remove it until it is needed. A device which is left unused for long periods should be stored with the battery partially discharged, and not recharged until just before the next use.
  • \$\begingroup\$ This is exactly what I was hoping for, thank you for taking the time to find data which is so graphic and quantitative and to summarize it so well! The distinction between number of cycles and total excursion in relative charge (%) is important to interpreting the data, and you've explained it clearly, along with the mechanisms and interplay of temperature, and of charge level during storage. \$\endgroup\$
    – uhoh
    May 1, 2016 at 1:47
  • \$\begingroup\$ Hmm...so it's not a constant total energy over the life of the battery. (simple sum of all charge/discharge cycles) If it were, then most of this would be moot. \$\endgroup\$
    – AaronD
    Aug 11, 2022 at 1:16
  • \$\begingroup\$ Also, I think the graphs are misleading. At first glance, it looks like they're discharging the battery to 80% or 20% remaining, denoted by the red line, when they're actually testing the top 80% or 20% capacity and leaving the rest. \$\endgroup\$
    – AaronD
    Aug 11, 2022 at 1:18
