I was doing a performance monitoring for my sine function and interestingly when I use the variable a in the sine as 16 bit unsigned types it takes more time to calculate than when I use the same variable as a 32 bit unsigned. Could this be because inside the sine algorithm in math.h/.c it takes more time to type caste the 16 bit type ??
This is how my operation looks like, start_performance, for(50 times) { a=sin(a*3.14/180); } stop_performance_and_read values
My performance monitoring unit works fine , its just that I dont understand why the result is odd.
