How would one mount a fuse that is 3,6mm in diameter and 10mm in length on a PCB? I can't seem to find a method to do this, browsing through the electronic components suppliers.
Datasheet: http://datasheet.octopart.com/MCPDS-004-Multicomp-datasheet-10027002.pdf
  • \$\begingroup\$ This appears to be a shopping question. However, it may be useful to answer. It does not need a fuse holder. The fuse can be held by two individual clips in a PCB, e.g. Fuse Clips On a page that lists that type of fuse Farnell have a link to their catalogue. That shows a PCB mount fuse holder in the right-most column. Unfortunately, the part number is wrong! Email Farnell sales and ask for the correct part number. \$\endgroup\$
    – gbulmer
    Commented May 2, 2016 at 22:09
Looks like you would use individual clips mounted in a pcb. http://bentronics.com/index.php?main_page=product_info&cPath=16_85_87_132_788&products_id=4065 enter image description here
