-2
Hello I've got this Component with an arduino pack and I want to know what it is.
It only has one label on it "HDX" I googled it but didn't find any thing it has also one short golden leg and a normal leg I can hear something inside it moving if i tilt or shake the component
Can anyone please tell me what is that component and how it works?
    \$\begingroup\$ I would say its wood. Plywood maybe? Not sure from the angle, you can hardly see the side. Looks dirty and not well lit, might be birch \$\endgroup\$ – PlasmaHH May 4 '16 at 13:18
  • \$\begingroup\$ Thanks for your effort captain @PlasmaHH you're so funny :) \$\endgroup\$ – Th3Wolf May 4 '16 at 13:21
  • \$\begingroup\$ Why does this have 2 down votes? Its good question in my opinion. \$\endgroup\$ – wav scientist Jul 19 '18 at 17:11
It's a vibration switch according to this article here.
It is a Vibration switch. Below image shows the internal construction.
Shaking it should break the connection between the ends momentarily.
Your comment that you can "can hear something inside it moving if i tilt or shake" it indicates that it is probably a rolling-ball tilt/movement sensor.
If you wire it into a circuit with an LED, or even just attach it to a continuity tester you should find that such movement makes/breaks the circuit.
  • \$\begingroup\$ Thanks you Chris I just realized that it is a vibration switch. \$\endgroup\$ – Th3Wolf May 4 '16 at 13:17
