-1
I dont have a lot of smarts on circuitry design, so this is more of a can i do it, and what should i look at using or is there is a current solution.
basically we have some wireless PIR's with our security system that run off 9v batteries.
The batteries go dead usually at night time around 3am, and im trying to see if i can power the PIR with a power adapter (wall wart or similar, hopefully wired to a central location up to 20 metres away. (some are closer, around 2-5 metres)
I was hoping basically to have the PIR wired to a cat5 cable, (just because we have lots) and then run that in the wall or in conduit to a cabinet where the adapters would be, or even have one PCB or device that powers all the PIR's... as in 1 x 240v unit that isolates and distributes the 9v to each PIR individually.
any ideas or can anyone steer me in the right direction.
Update i was talking to an electronics guy and he said that i have to be careful about the wire becoming a radio antenna, and affecting the transmission to the control unit with power fluctuations. he mentioned about checking if the PIR has power filtering built in, otherwise it could be another reason for using batteries in the PIR's... i.e. batteries are in there, so they dont add the filtering...
So i have to look into that with the manufacturer.
sorry.
  • \$\begingroup\$ Did you actually do your installation and what did you choose at the end? I'm having same idea to do it as well in my house. Thanks to let me know \$\endgroup\$ – Juls Mar 30 '17 at 12:02
  • \$\begingroup\$ Hi Julien. No i didn't go ahead in the end, i was talking to a few techs and they warned against it, too many add ons can complicate the circuit, and i dont need to be the only one that knows how its wired and why. Trying to lighten the work load, not make it more difficult. I feel keeping the pirs on battery will mean a constant voltage supply, without the need for a ups and sine filters etc installed. An effective Maintenance regime this time won. good luck with your ventures though, everything everyone has mentioned here all valid, and much needed in terms of voltage drops and allocating en \$\endgroup\$ – JCmurphy Mar 30 '17 at 12:15
There are cable adapters that allow you to carry power over ethernet cables, called Passive PoE, which is not the same as PoE. This helps if your cables have RJ45's on the ends. You can google for "passive power over ethernet". One example: https://www.sparkfun.com/products/10759.
In terms of can I do it - probably. Check the voltage drop on the wires. V_at_box = Vsupply - 2 * Iload * Rwire. It's 2 x because the voltage will drop over both the positive and return wires. Make sure V_at_box is adequate.
Also check that the supply current provided by the wallwart is enough for the sum of the remote load currents under their worst-case load conditions and then add some margin. If there are 5 remote loads that range from [50-90] mA, then the total worst-case load is 450 mA. I'd oversize the adapter for 600 mA, or more likely 1 A. 1 A will be a common size and won't cost much more. So 1 A is good, cheap insurance that the wallwart will function over all conditions.
Also, if you use a wallwart, and the adapter body is external to the DC junction box where you break out the DC power to the cat5 cables, then you've kept 120/240 VAC out of the box from whence the DC power cables are run. It's worth doing.
You may want to use multiple wallwarts, perhaps one per circuit, if there is a reasonable chance that a failure will occur, either from damage to the DC power cable, or in the end device itself. Say for example that the cable was going outdoors and might take on water. You don't want one device/cable failure taking down the whole system. So if there's a reasonable chance, then you can mitigate that risk by using additional wallwarts to protect failures from taking the whole thing down.
| improve this answer | |
  • \$\begingroup\$ Thanks for the reply, sorry about the delay. thanks for the info re the circuitry and options re the cat5 POE adapters.im looking into all the options at the moment \$\endgroup\$ – JCmurphy May 10 '16 at 8:29
If your security system has been installed correctly it will have an internal battery back-up so if the power goes off the security system continues working. If you connect your PIR's to mains power then if it fails part of your security system will stop working.
Since you are prepared to run cabling in the walls a better solution would be to use the security system control panel to provide the power to your PIR's, along with battery back-up. Security systems work from 12V, so you will need a small module (you can buy from eBay) to drop the voltage down to 9V, but this should then be able to power all of your PIR's. Wireless PIR's take less than 1mA in quiescent state, and around 20 to 30mA when transmitting, so power should not be an issue.
  • \$\begingroup\$ Hi Steve G, thanks for the reply, im wanting to add on, rather than have to rewire / effect the control panel. thanks for the info though around the power usage for the wireless PIR's \$\endgroup\$ – JCmurphy May 7 '16 at 12:17
