What type of metal are the tips of USB connectors/plugs typically made from? Aluminium?
I've noticed they will often, quite-easily, oxidise/rust/corrode.
  • \$\begingroup\$ Which part is "the tips"? Do you mean the electrical contacts inside the plug/socket, the metal shield, or something else? \$\endgroup\$
    – gbulmer
    Commented May 7, 2016 at 3:50
  • \$\begingroup\$ @gbulmer The tips; the extremities, the points of contact/termination. (So both, I guess?) Admittedly, I assumed they would all be the same material. But obviously there is a bit more to it than that. \$\endgroup\$
    – voices
    Commented May 7, 2016 at 3:57
  • \$\begingroup\$ Okay. I must admit, I have probably more than 100 USB cables, and I have never noticed rust or corrosion. The vast majority of my cables are full-size or full-size to mini USB. Is this a phenomena you've noticed on mini, micro or any USB? \$\endgroup\$
    – gbulmer
    Commented May 7, 2016 at 4:06
  • \$\begingroup\$ @gbulmer Now that you mention it: Mini only, I think. Like the one often used by external USB WLAN interface cards and other small peripheral devices. \$\endgroup\$
    – voices
    Commented May 7, 2016 at 4:12
Well, quick search at Mouser gives:
For this model:
And for this:
So I'd say stainless steel, some gold plated copper alloy(brass) and flame retardant plastic.
  • \$\begingroup\$ The contacts themselves are made of brass. They are usually plated with gold. Sometimes, they are plated with tin to save cost. \$\endgroup\$ Commented May 7, 2016 at 3:49
  • \$\begingroup\$ Very nice, cheers. I wonder why they plate it with a tin alloy; wouldn't it be better to just leave it stainless steel? \$\endgroup\$
    – voices
    Commented May 7, 2016 at 3:51
    \$\begingroup\$ @NickAlexeev brass is a copper alloy :P (added your info to the answer) \$\endgroup\$
    – Wesley Lee
    Commented May 7, 2016 at 3:58
    \$\begingroup\$ I believe not. I dont know but I'd guess its something to do with chemical bonding of different metals. Just a wild guess. \$\endgroup\$
    – Wesley Lee
    Commented May 7, 2016 at 4:07
    \$\begingroup\$ Not bad for a wild guess, stainless steel grows a protective coating of nickel oxide, tin plating provides a surface that's easier to solder to (the tin will dissolve in the solder). once the stainless steel is wet with solder air is excluded, and no nickel oxide layer forms. \$\endgroup\$ Commented May 7, 2016 at 8:32
