I am trying to simulate a testbench on ModelSim, but when I run the simulation, it never advances in time. The delta does not increase, either.
Are there any useful tips for debugging in a situation like this? I suspect that the problem may not be in my testbench, but in the maze_solver entity itself. Here are some possible problems:
  • maze_solver also contains a structural description for another entity within it. Is it okay to simulate like this? As long as I have added that other entity into the ModelSim project?
  • Could it be a problem with my sensitivity lists? I have checked them all, and all the right-hand side signals have been included on the sensitivity lists.
  • Could it be a problem with my testbench? I have included the testbench code below.
Since the maze_solver design is long, I have not included it, but I can include it if necessary. It is a finite state machine (uses only case and if statements).
Below is my testbench:
library IEEE;
use IEEE.std_logic_1164.all;
entity solver_testbench is
end entity solver_testbench;
architecture tb of solver_testbench is
signal clk,reset: STD_LOGIC;
signal cell_data: STD_LOGIC_VECTOR (7 downto 0);
signal data_rdy: STD_LOGIC;
signal rd, wr: STD_LOGIC;
signal row, column: integer;
component maze_solver is
    generic(maze_width : in integer);
    Port (clk, reset : in STD_LOGIC;
        start : in STD_LOGIC;
        rd_cell_data : in STD_LOGIC_VECTOR (7 downto 0);
        data_rdy: in STD_LOGIC;
        rd,wr: out STD_LOGIC;
        row, column: out integer
end component maze_solver;
begin
aravindans_maze_solver: maze_solver
    generic map(maze_width=>2)
    port map(clk=>clk, reset=>reset, start=>'1',rd_cell_data=>cell_data, data_rdy=>data_rdy, rd=>rd, wr=>wr,
         row=>row, column=>column);
process
begin
clk <= '1';
wait for 10 ns;
clk <= '0';
wait for 10 ns;
end process;
process
begin
cell_data <= (others=>'0');
if rd = '1' then
    if row = 0 and column = 0 then
        cell_data <= "01000000";
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
    elsif row = 0 and column = 1 then
        cell_data <= "00010000";
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
    elsif row = 1 and column = 0 then
        cell_data <= "00000000";
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
    elsif row = 1 and column = 1 then
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
    end if;
else
    cell_data <= (others => '0');
    data_rdy <= '0';
end if;
end process;
reset <= '0', '1' after 5 ns;
end architecture tb;
  • \$\begingroup\$ If the delta count isn't increasing, it isn't a conventional combinational loop (which would timeout when the limit on deltas was exceeded). Look for loops within any processes, such as while loops, which may accidentally be infinite loops. \$\endgroup\$ – Brian Drummond May 7 '16 at 19:40
Assuming maze_solver is bound, you are not getting some combination of rd, row and column values that cause execution of a wait statement in the second process.
Simulation time doesn't advance while any process is executing removing any possibility of getting any further combination of values leading to a wait statement. A deadlock. The process reaches it's last sequential statement and starts over at it's first without suspending.
It'd be possible to re-write this process driven by a clock event and depending on internal state.
Add a wait statement that will always be reached:
process
begin
if rd = '1' then
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
        data_rdy <= '1';
        wait for 20 ns;
        data_rdy <= '0';
    end if;
else
    data_rdy <= '0';
end if;
wait for 20 ns;  -- ADDED WAIT
end process;
You may have to tinker a bit once you get simulation time advancing.
