I am looking for a simple program that can send data down the serial to the PIC. I have used Putty with USB-UART converter on my laptop. I have made the PIC->PC communiation work which is frankly a trivial task.
The question is, how to do the opposite. I can't find any option in Putty to send data down the serial port. What alternative do I have? Is the only option to use custom application written in C++/C#? It is better that I be able to implement flow control (of any kind) so the PC could be told to pause sending the data.
    \$\begingroup\$ Did you try typing the data into PuTTY directly to test it? \$\endgroup\$ – Transistor May 8 '16 at 21:13
    \$\begingroup\$ There is an option in PuTTY to use flow control. I always disable it because usually I don't want it. \$\endgroup\$ – mkeith May 8 '16 at 21:28
PuTTY works well as a general terminal emulator but for work with embedded systems I prefer Realterm which has a lot of support for working with binary / hex. When sending a file you get the option to set a delay between each character, each line and can send the same file multiple times with a delay between each time:
Realterm send
So using that you could either add delays or implement flow control (which is set on a different tab). Another alternative to using flow control is to implement one of the fairly ancient protocols like XMODEM which are fairly simple and don't consume a lot of code space, if you have a little over 1k of RAM available then I've used this code and it works. ExtraPuTTY is a fork of PuTTY that adds XMODEM and a few other file transfer protocols.
|improve this answer|||||
Assuming you want to send a HEX or command file ...
See Is it possible to send the content of text file over PuTTY over serial port where a solution is given using PLink (PuTTY Link, I presume) which should be part of the PuTTY install.
It's hard to ask an original question!
Under Terminal option, on Local echo: select Force ON
  • \$\begingroup\$ Not sure how this answers the question. \$\endgroup\$ – Finbarr Dec 5 '17 at 15:47
  • \$\begingroup\$ Default option only allow to receive data from the port. I think he know how to use putty and receive data. This option allow to send data \$\endgroup\$ – Angel Dec 6 '17 at 3:15
