I am using an RS 485 serial connection through which I need to send S19 files for my boot loader project. Since it is a half duplex mode of connection, I need to toggle a dedicated pin before sending and receiving. I am using this terminal application. I got the desired output when I sent a string.
But I couldn't get any output when I try to load a file (s19 file to be specific). Is it because of the Half-Duplex connection I use ? Will an RS 485 to RS 232 converter change the mode from Half duplex to Full duplex ?
UPDATE
I am working on Freescale's MKE02Z64VLD2 microcontroller. I just now found out that there is no RTS CTS pin in my controller. (Check Comment Link 1)
This is the Serial connection which I use,
And the Terminal application is not a boot loader GUI, I found it in this site. (Check comment Link 2) Thanks for helping. I am posting the Links in the comments section because I dont have enough reputation to post more than 2 links
