I have a 5V "SG90 Servo motor" and would like to control it to move 0 degrees, 90 and 180 degrees, by sending it appropriate pulses from my NodeMCU Development kit.
Having searched on the net - I could not find a right example source on how to essentially program it.
Arduino IDE has some examples -but they are for Arduino hardware and not for NodeMCU/ESP 8266. ( I am using this to upload code to the NodeMCU )
There is a "sweep" sketch/program and I used/modified it a bit to suit the NodeMCU pin out, that did NOT work. Hence reaching out to any engineers here who can share code snippet ( prefer python) and show how to control the Servo motor .
The Pins on the Node MCU I would like to use are D1..D4. I have a 5V wall adapter from which I can power the Servo's Power ( Vcc) and GND pins. The orange pin (i.e PWM ) on the SG90 Servo, is how I am trying to control the Servo from the NodeMCU's D1.. D4 pins.
Any help would be appreciated.
closed as off-topic by Voltage Spike, Dmitry Grigoryev, Andy aka, uint128_t, Dave Tweed Dec 25 '16 at 19:20
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Voltage Spike, Andy aka, uint128_t, Dave Tweed
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Do you have preference for which approach to ESP8266 programming you use, ie, native, Lua, or the Arduino port? I'm getting plenty of results if I do a web search for "ESP8266 servo" \$\endgroup\$ – Chris Stratton May 9 '16 at 17:19
    \$\begingroup\$ Are you using the NodeMCU firmware (that is, the Lua-based firmware)? A servo requires a pulse between 1ms and 2ms (1.5ms is middle), and the NodeMCU firmware provides a PWM library that allows you to set frequency, so all that's left for you to do is math. \$\endgroup\$ – uint128_t May 10 '16 at 1:00
With NodeMCU you can use the pwm module like this:
local pin4 = 4
--setup at position 0
pwm.setup(pin4, 50, 71)
--turn to position -90
pwm.setduty(pin4, 27); pwm.start(D5); tmr.delay(500000); pwm.stop(D5)
--turn to position 0 again
pwm.setduty(pin4, 71); pwm.start(D5); tmr.delay(500000); pwm.stop(D5)
--turn to position +90
pwm.setduty(pin4, 123); pwm.start(D5); tmr.delay(500000); pwm.stop(D5)
27, 71 and 123 are the appropriated duty cycle "time" to set the desired position from 0 to 180 degrees up. I found this by experimenting.
For more information you can check the sg90 manual here and pwm module manual here.
With Nodemcu you can drive the servo by generating high and low pulses with any GPIO pin. In the code below a potentiometer is used to vary the duty cycle.
Potentiometer = 0   --setting the pot value  level adc pin
servo_PIN = 2       --pin for connection of servo
Max = 2400
Min = 700
tmr.alarm(0,20,1,function () -- 50Hz
value = adc.read(Potentiometer) --Read the adc pin
value2 = (value-2)*(Max-Min)/(1024-2)+Min
gpio.write(servo_PIN, gpio.HIGH)
tmr.delay(value2)               --Delay for setting the servo position
gpio.write(servo_PIN, gpio.LOW)
end)
tmr.wdclr() -- Internal Nodemcu OS function
