-4
Are there any chances it may damage my computer?
closed as off-topic by PlasmaHH, Dmitry Grigoryev, PeterJ, Peter Smith, Ricardo May 12 '16 at 12:20
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – PlasmaHH, PeterJ, Peter Smith, Ricardo
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ It's unanswerable - if it needs to be earthed, then it needs to be earthed, if it doesn't, it doesn't. Use whatever came with it. \$\endgroup\$ – user1844 May 12 '16 at 8:03
  • \$\begingroup\$ Actually it came with 3 prong power cord but i needed to extend the cable and i had this 2 prong extension cord so i plugged in my 3 prong cable into 2 prong... is that safe? \$\endgroup\$ – john jody May 12 '16 at 8:06
    \$\begingroup\$ Safety earthing was just discussed here. \$\endgroup\$ – Dmitry Grigoryev May 12 '16 at 8:23
It is generally unsafe not to earth equipment which was designed to be earthed e.g. a typical mains-powered desktop computer, as in your question.
This is because, in the event of a fault which causes any exposed metal to become "live", the fuse will not blow, since there will be no large current flowing via that (now missing) protective earth wire. :-( Therefore you could be electrocuted by touching the (now "live") metal case and having any other current path (e.g. through your feet, or other hand etc.) to earth.
Based on your description, please do not extend the 3-core mains cable to your desktop computer, with a non-earthed 2-core cable.
Your chassis will float to half the mains voltage, 115 Vac in 230 Vac countries and 55 Vac in 110 Vac countries, due to the Y-caps between N-GND-L in the power supply of your computer. This may seem harmful but the current though them are limited by goverment standards to 750 uA. This can hurt you, but not enough to kill you. Your EMI will be very compromised too and you may experience excessive 50/60 Hz hum in audio. Whenever I don't have access to earth, I do it like you and run without but please pay attention/measure when you need to connect things like computer -> stereo/TV/antenna, where you may short this 115 V to anouther local or real ground.
  • \$\begingroup\$ This incorrect and not safe - the 3rd pin is there for a reason - to provide a ground patch for a device that isn't double isolated. A single failure in the device could be deadly without the earth pin connected. \$\endgroup\$ – RJR May 12 '16 at 9:55
  • \$\begingroup\$ I never said it wasn't there for a reason. I explained what will happen if you run it without earth. Your power supply is also double insulated apart from the Y-caps whch are guaranteed not to fail to short, so any single fault will never bridge L-GND or N-GND. \$\endgroup\$ – winny May 12 '16 at 10:24
  • \$\begingroup\$ How do you know the power supply is double insulated (Class II)? Most standard computer power supplies are not. If it were, it would have come with a two-prong cable. \$\endgroup\$ – RJR May 12 '16 at 10:32
  • \$\begingroup\$ The output side is a Class 2 part of an otherwise Class 1 product. You'd be amazed how many are only relying on the ground to meet EMI but all electrical saftey is taken up in the double (required, but tripple inside the transformer) insulation. I've designed and put several into production myself. \$\endgroup\$ – winny May 12 '16 at 10:36
  • \$\begingroup\$ Hmmm, the ATX supplies I've pulled apart (a few) all had the mains connection wires soldered to the PCB without any extra insulation of the through-hole joins. I don't see how that can be class II with the PCB mounted on standoffs in a metal container. In your case, the wires would have to go straight into the (triple insulated) transformer from an insulated connector. example: xbitlabs.com/misc/picture/?src=/images/other/atx-psu8/… \$\endgroup\$ – RJR May 12 '16 at 10:47
