I am new to electronics so I hope this question is acceptable. I have been playing around with an Arduino. I have use the USB output from a computer as a power source. I also have a 9V battery. I am a bit concerned about creating a short somewhere and damaging the computer or the battery. I am guessing that this is what a fuse is for, is that right?
For small projects (not necessarily involving an Arduino) what type of fuses should be used? Is it, for example, possible to get a 1A 9V fuse? I have searched online and I only see things like 1A 250B fuses. Will these work well for small electronics projects?
    \$\begingroup\$ possibly take a look into resettable fuses/polyfuses and/or bench power supplies with current limiting \$\endgroup\$
    – Wesley Lee
    Commented May 12, 2016 at 21:19
4 Answers 4
To answer your question, yes, those 1 Amp 250 Volt fuse will work fine in small projects, as the Voltage is a maximum. A 1 Amp 250V fast fuse should blow even at lower voltages. The important number here would be the Current rating.
For example, my multimeter has a 500 mA 250 Volt fast fuse, with a recommended/listed max current measuring of 200 mA. It has blown when I shorted out a 5V 1 Amp (USB) supply, and a 12V 750 mA supply by mistake.
You can test this with a spare fuse, and a resistor. Take your 9V supply and a 100 ohm resistor. At roughly 90 mA, the fuse won't blow. Short the fuse out, and it should.
Look up 'Pico Fuses' on the web. They are small PC mount fuses, in a package that looks like a 1/4 watt resistor. They are rated for 50 to 125 volts max, with currents as low as 1/20th of an amp to 5 amps. These are fast-blow uses, so be sure to use them in places where the in-rush current is low. Digi-Key and Mouser supply them in small lots or in bulk.
Fuses have voltage drop. A garden-variety 1A 250V 5x20mm fuse will drop about 200mV, so not too bad, but it might put the USB voltage out of spec with a long cable.
'Most' modern USB ports are protected against shorts (and the computer knows if they have been overloaded), but I have seen old motherboards with soldered in one-time fuses.
These glass tube 250V fuses are fine. Make sure they are fast-blow fuses. Some have lower voltage but it's less common. Prior to choosing a fuse, evaluate approximately the extreme maximum current your project may take. If you think it will never use more than 500 mA, then use a 500 mA fuse. Some projects may work with 250 mA or even 125 mA fuses. The lower the safer. A fuse will help you debug your circuit on top of protecting it.
