I am operating PCIe over copper cables via re-drivers asynchronously. i.e. I only send over the RX/TX data.
The clock is sourced locally at the end point. For the host root port, I am designing a little PCIe add-in card that will have a PCIe re-driver.
For the add-in card I am wondering if I will need some sort of spread-spectrum clock squelching circuitry.
I am concerned that there will always be some hosts that will not let me turn off the spread-spectrum clocking.
Thank you in advance.
You are operating the link in a source synchronous manner.
PCIe has a mechanism for crossing the receiver and local clock domains: the skip ordered set.
Provided the spread spectrum clock is a low enough frequecy in the link such that a receiver overrun cannot occur, you should be ok.
[Update]
Timing details.
Spread spectrum clocking was formally introduced in generation 3 but included all data rates.
The rules are quite simple:
\$F_{ss}\$ \$ 30kHz \le 33kHz\$
Modulation depth -.5%, 0% (therefore down spreading only is permitted).
A skip ordered set is scheduled (for generation 2) at between 2.36μsec and 3.076μsec. Given the spreading, it will have varied the output data edges by 7 psec which should not be an issue provided you have some margin on ISI
I cannot see a way you can remove spread spectrum from a signal that includes it without doing full clock and data recovery.
You can find an excellent discussion here and here
