I'm having an analog project where I have to amplify a weak signal coming out of a photo transistor. I used LM741CN OpAmp for this and found out that nothing comes out as the output when connected to a RS232. So I tried creating a basic inverting amplifier using this IC and the oscilloscope showed the same input signal like waveform as the output signal. I tried with another LM741CN IC and it gave the same result. Addition to that, the IC seems to be heating up a lot. Then I tried a non inverting amplifier but that didn't work too. Same input signal as the output. I tried 4 other 741CN ICs I bought from the shop the same day and all not working. (I assumed that it's not possible for 6 chips to be burnt like that) One of my friends had a LM741CP IC and I plugged into the same proto board with the same pin configuration and it worked.
So my question is are these LM741CN and LM741CP different? Do these last letters N and P mean anything like p type or n type?
EDIT: Here I've added the circuit diagram I used to create the inverting amplifier. The project description was to create a background. My problem is about the difference between LM741CN and LM741CP. Since I couldn't make the circuit with 6 741CN ICs, I used LM386 and it worked. Was just wondering why CN didn't work when CP did.
closed as unclear what you're asking by Matt Young, PeterJ, Daniel Grillo, Dave Tweed May 16 '16 at 0:57
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ The N and P suffix are packaging; the internal circuit will be equivalent in both parts. We can only help when sufficient information is presented; draw a circuit diagram - the small circuit widget in the edit controls will open a schematic editor. \$\endgroup\$ – Peter Smith May 14 '16 at 14:28
    \$\begingroup\$ If you want to know about LM741CN versus LM741CP see the datasheet I am too lazy to do it for you. But my guess is that they are electrically identical. Also the 741 is ancient You better use a TL071 or TL081, even those are old but much more suited to many of today's applications. \$\endgroup\$ – Bimpelrekkie May 14 '16 at 14:30
    \$\begingroup\$ Yes, post a circuit. No idea what you are doing. Is it an analog circuit? What is the RS232, then? Can't figure out what you are talking about. \$\endgroup\$ – mkeith May 14 '16 at 14:34
    \$\begingroup\$ The LM3886 is not an op amp. It is an audio power amplifier. Don't use it like an op amp. \$\endgroup\$ – Matt Young May 15 '16 at 15:03
Unfortunately some parts of your project are unclear. However I can answer the main question and give a suggestion for a possible cause of your problem:
OK.
I used LM741CN OpAmp for this and found out that nothing comes out as the output when connected to a RS232. [...] The project description was to create a background.
Just to let you know, this description of your project doesn't make sense e.g. there is no RS-232 connection shown on your schematic, and you want to "create a background" - a background what? Background lights? Background music? Background dancing? :-) There is no explanation in your schematic, so readers won't understand your actual project and cannot take those details of your project into account in any answers.
Any ICs heating up when they should be dissipating negligible power, is a clear indication that either they are faulty (perhaps counterfeit), or you have made a mistake in your circuit construction / design. Since you explain later that a replacement LM741CP worked OK in the same circuit, then that strongly suggests that the LM741CN ICs were faulty.
Wrong assumption. Shops can get faulty batches of components, or perhaps counterfeit etc. Ebay and similar sources outside the official manufacturer's supply chain, have a higher chance of counterfeit components. Depending where your shop sourced the components, then these are some of the possibilities you should consider.
Good! So as I explained above, this result tells us that the LM741CN ICs you tried earlier, are faulty.
No. LM741C = commercial temperature range LM741.
In this context, no. The suffix "N" = plastic DIP package type is used by some manufacturers e.g. National Semiconductor / some Texas Instruments. The suffix "P" = plastic DIP package type is used by some other manufacturers - Texas Instruments also use the suffix "P" to indicate plastic DIP packages on some of their ICs. In this context, "N" and "P" suffixes both mean plastic DIP packages. That is all.
Other packaging type letters are also used, but these can all vary between manufacturers. Therefore use the manufacturer's logo on the top of the LM741CN and LM741CP ICs to identify the manufacturer, and then locate the relevant datasheet on their website if you want to find more details.
Looking carefully at the sequence of events, there seems a possible cause. It seems that at least 4 of the 6 faulty LM741CN ICs came from the same source - the shop which you mentioned. What about the other 2 faulty LM741CN ICs - did they also come from the same shop? The working LM741CP IC came from a different source - your friend.
So the difference could also be described as (most? all?) LM741C ICs sourced from the shop did not work. An LM741C IC not sourced from the shop did work. Where do you see the difference now? :-)
Therefore it seems possible that some or all of your problems could be explained by a faulty or counterfeit batch of LM741CN ICs, since at least 4 of them (from your story) came from the same source.
Readers here cannot exclude the possibility that you somehow damaged the LM741CN ICs in your testing/experimentation, because we did not watch what you were doing. :-) However, as you describe the events in your story, it seems unlikely to me that you would damage all the LM741CN ICs and then not damage the LM741CP IC.
Therefore faulty LM741CN ICs seems a likely explanation, based on your description.
[As other members have already kindly stated, there are good reasons not to use the LM741 for new designs these days, unless you have good reasons to do so. Carefully read the 741 datasheet and understand its limitations.]
  • \$\begingroup\$ Should have asked 'What is the difference between letter N and P at the end of LM741C' instead of giving out details of the project to create a background to the question which made people drove outta their minds :) Why can't they just answer the question asked in the heading? O.o I tried with two shops. They sell only CNs. Some other shop sells CP and they work. Somehow I got the project done perfectly without LM741s. Just asked this q to get to know what this N and P are! \$\endgroup\$ – Blogger May 21 '16 at 2:20
"So my question is are these LM741CN and LM741CP different?"
Don't ask us, look in the datasheet (that really should have been obvious).
That fact that one heats up and the other works suggests the pinouts are different.
READ THE DATASHEET
  • \$\begingroup\$ When I google, for both ICs, it's the same datasheet. Accepted answer provided a better insight! :) \$\endgroup\$ – Blogger May 21 '16 at 2:17
