I decided to build a colpitts oscillator using a jFET (2N3819): jFET colpitts oscillator
It seems to work fine @ http://www.falstad.com/circuit/ but when i try to build this circuit it does not work, any ideas?
Thank you in advance.
  • \$\begingroup\$ What voltage do you see on the drain? Ditto on the grid? (er, gate)? \$\endgroup\$
    – user16324
    May 15, 2016 at 20:22
Is transistor modeled in the simulator the 2N3819?
EDIT: https://www.fairchildsemi.com/datasheets/2N/2N3819.pdf
Sorry, for the not-too-insightful initial thoughts on your question. By the looks of the data sheet above, the transistor you're using operates on much larger voltages than the one in the simulator.
  • \$\begingroup\$ I don't think so, no. Thanks for the answer. \$\endgroup\$
    – Waffle Man
    May 15, 2016 at 17:37
  • \$\begingroup\$ edited my initial answer \$\endgroup\$ May 15, 2016 at 17:45
