I'm doing a full-adder using logic gates and I want to express the carry bit with a gate.
So I found the minterms of the carry bit
x'yz + xy'z + xyz' + xyz
Is there a 3-input gate that does that expression just like the 3 way XOR?
for example:
x XOR y XOR z = x'y'z + x'yz' + xy'z' + xyz
  • \$\begingroup\$ Its not clear what you mean by this question. For anything other than some simple 2-input gates, there are many possibilities to generate compound gates. In ASIC libraries, these are common. In FPGA, the implementation doesn't target gates, it targets lookup tables. \$\endgroup\$ May 19, 2016 at 11:28
You can use a K-map to reduce the number of logic gates needed. It helps to draw out the truth table for the MSB (carry - out) to fill in the K-Map.
The beauty of the K-map is that circling neighboring squares allows you to simplify the Boolean expression. You see there are 3 pairs circled. Then how many gates would you need?
Carry Out K-Map
Another hint to remember is that you can turn sum of products logic to NAND-NAND logic further reducing the types of gates needed.
I have never seen a 3 input Majority Gate. I am answering the question in terms of gates I know exist such as AND, OR, NOT and NAND gates.
I am wondering if you are using 7400 TTL gates. If that is the case, I don't think a 3 Input Majority gate exists.
  • \$\begingroup\$ That's very nice. What's your answer to the question? \$\endgroup\$
    – pipe
    May 19, 2016 at 19:47
Yes, it's called a 3-input "majority" gate, or MAJ3 in some libraries. You won't find one as a discrete device, but many FPGA libraries include such a function.
You do realize that the fourth term in your Boolean expression is redundant, right?
Note that...
reduces to a simpler form
xy + xz + yz
As can be seen from the truth table.
XYZ
000 | 0
001 | 0
010 | 0
011 | 1
100 | 0
101 | 1
110 | 1
111 | 1
This is a majority gate.
If you are buying chips to make this then you may use a three input and gate and three or gates.
Dual 3 input AND gate SN74HC11N
DATASHEET: http://www.ti.com/lit/ds/symlink/sn74hc11.pdf (Datasheet)
http://www.digikey.com/product-detail/en/texas-instruments/SN74HC11N/296-8217-5-ND/376871 (Buy it on Digikey for $0.50)
Quad 2-input OR gate SN74HC32N
http://www.ti.com/lit/ds/symlink/sn74hc32.pdf (Datasheet)
http://www.digikey.com/product-detail/en/texas-instruments/SN74HC32N/296-1589-5-ND/277235 (Buy it on Digikey for $0.46)
