We are working on a product which is extremely cost sensitive. It generates a lot of heat so we are planning to use a heat sink. For those 'very rare edge causes' where heat sink alone cannot cool down the system, we have also equipped the system with a cooling fan.
Due to cost constraints, we are planning to go with cheap 12V DC cooling Fans (basically used parts, the ones which don't come with a guaranty). So now we are focusing to judiciously use the fan ONLY when absolutely required (The tests show heat sink alone can keep the system cool for ~75% of scenarios). Our system can tolerate a max. temperature of 85 °C.
To maximize the fan's life, we'll have to reduce it's wear and tear. And to do that, we have to decrease it's usage. For this, we have come up with two different solutions (there might be even more possible, we are open for suggestions!):
1. We control the fan's rotation.
We switch it on at a (relatively lower) 60 °C but at very low speed. Basically, the fan's rotation is directly proportional with temperature (like laptops). But because cooling fans rapidly lowers down the temperature, so even if running at 35% speed, the system will cool down rapidly and the fan can be switched off (say at 50 °C).
2. We raise the trigger point to ~70 °C.
The fan is switched on at full speed at 70 °C and switched off at, say ~60 °C. Fan speed is not controlled.
Which approach will work better? You may assume that our design is perfect in terms of heat transfer. The device is vertically mounted and hot air can easily escape from upper face (while cool air enters from bottom face). Assume no hot air is trapped inside the device.
Approach #1 tries to minimize power consumption (thus wear and tear), but it does not minimizes fan usage time. Approach #2 tries to minimize fan usage time (at the expense of power consumption).
So more Power Consumption for less time or less power consumption for more time, which will work better?
We have tried to weigh both of these approaches on following factors, but due to limited experience, we have been unable to choose which one is better:
1. Amount of dust deposited
More dust means more resistance and thus more power consumption leading to more wear and tear.
2. Air Temperature
Hotter air moving across the fan means more heating of fan coil, thus causing more damage and reducing fan life.
Approach #1 looses at Factor #1 but wins at Factor #2. Approach #2 looses at Factor #2 but wins at Factor #1.
Please we are looking forward for an expert advise on this matter. We have already looked into this, this, and this but are still stuck. Please forgive us if it is plain obvious, we have very little experience in dealing with such issues. We do not intend to ask a subjective question but to discover and learn about the best industry approach for such cases (if there is any?).
EDIT 1 Providing some more technical details.
Expected lifetime: min 5 years. Environment temperatures vary between 0 °C to 50 °C. Device can tolerate maximum of 85 °C.
What is the average / max power consumption?: Fan consumes ~1.32 Watts at full speed. System consumes constant ~10 KVa.
How big is the fan? Fan diameter is 73 mm.
How much dust is expected in the environment? If there is any, how do you prevent it from interfering with the passive cooling?: It is going to be a consumer product and thus we have to expect a dusty environment. Being vertically mounted, theoretically, only some dust should stick inside the heat sink's grooves (reducing it's surface area and heat conduction). Currently we have nothing to prevent this. Any suggestions for the same? i'll have to contact the the pollution department to get the exact data. i will get the data and revert back.
How many start / stop cycles of the fan are to be expected?: This depends upon the kind of approach we choose. But the way i see it, it depends how often we cross the 'critical' temperature without any fan (in the current prototype the fan is always running). For that we'll have to conduct some tests. We will publish the results in a day or so.
