I am (still) learning about electronic and want to get a 555 timer. From a datasheet (page 5) it looks like when the input voltage is 5V, then the output voltage is only 3.3V.
Is that correct?
If this is correct, are there any 555 timers (or similar) that will operate on inputs on about 5V and give outputs also 5V
(or just the same as the input)?
