I'm just trying to understand if my thinking is correct here. A "regular" ADC in my mind would have a number of quantization levels. Say 16 bits gives me 65535 levels, if I divide into my input voltage range I'll get a number in millivolts for each step. So for a 0-1V input range I get 0.015mV per step.
If my input voltage of my signal was only 0.5V I'd be throwing away half of the levels I could be using and losing accuracy I could have had.
Does this same thinking hold true for a 16 bit Delta Sigma, can I still think of it in terms of quantization levels of 0.015mV even though it's being converted into a train of pulses and then decimated?
Would they both have the same level of accuracy? Would the Delta Sigma be more immune to noise and so have a higher accuracy?
I've never used one before so I was reading up on them today.
    \$\begingroup\$ So whats a regular ADC? Sigma delta is an ADC, also in the group of regular ADC, as there doesn't exist a group of irregular ADC. \$\endgroup\$ Commented May 20, 2016 at 19:18
  • \$\begingroup\$ I was thinking of direct conversion A2D I guess. The simple form you learn about in school, although school was a long time ago for me maybe all they talk about is Delta Sigma now ;) \$\endgroup\$
    – confused
    Commented May 20, 2016 at 19:23
  • \$\begingroup\$ A2d is abrevation of ADC, look for listo of ADC types: en.wikipedia.org/wiki/Analog-to-digital_converter \$\endgroup\$ Commented May 20, 2016 at 19:27
  • \$\begingroup\$ Some of the main differences are going to be in the noise floor (delta-sigmas have a way to move the noise to places where it's less of a problem) and with the propagation delay. Flash ADCs (i.e. the fastest ADCs) have a sample delay of one cycle, a one bit delta sigma (though they can be multibit too) will have a substantially longer delay as it needs to average out all those low res samples. \$\endgroup\$
    – Sam
    Commented May 20, 2016 at 22:17
The number of bits usually is a good indicator for the performance of an ADC. To quantify the true performance other measures like ENOB (effective number of bits) are better.
A delta-sigma ADC with an ENOB of 16 bits is as good as any other converter with that performance. However, delta-sigma converters consist of a noise shaper and a decimation filter. The resolution is determined by the order of the noise shaper and the decimation factor. For some converters it is possible to change the decimation factor and trade off speed for resolution.
Oversampling and averaging can also be used for Nyquist rate converters, but the improvement is usually not so high, since no noise shaping is done.
A direct conversion ADC requires \$2^{n-1}\$ comparators, so their resolution is usually lower than that of delta-sigma converters. A larger number of comparators also means better comparators (since we have a higher resolution), therefore they are much more costly.
For a given number of bits, say 24, a delta-sigma ADC is normally used for continuous signals such as high-definition audio. The delay time to propagate the signal to the ADC output is tolerated because it is small compared to the final sample rate of 176KHZ or 96KHZ, with 120dB of dynamic range possible.
Most lab instruments use conventional but fast direct conversion ADC's for single sample or burst samples of a continuous or slow changing signal, or precision DC measurements as fast as 100 gsps. They can be much more expensive then the delta-sigma type, but they can gather transient and RF details that a delta-sigma cannot.
The noise filters and decimation would distort the raw signal, and simultaneous sampling of multiple channels would be difficult at the raw sampling frequency. There are exceptions such as ultra-accurate bench-top DVM's and medical equipment that can over-sample to make to for the delay to the delta-sigma ADC output.
Conventional direct conversion ADC's are easy to synchronize above 100MHZ sample rates if needed, though the resolution may drop down to 10 to 18 bits. Both type of ADC's are needed to cover the wide variety of instruments they are in, and to meet the desired goals of the designer.
