I wrote a vhdl code, that would display 4 digits on cpld 7-segment displays. I used a state machine to select the display, and with ... select instruction to select a set of bits given to the current display.
entity disp is
Port ( clk_in : in STD_LOGIC;
an1 : out STD_LOGIC;
an2 : out STD_LOGIC;
an3 : out STD_LOGIC;
an4 : out STD_LOGIC);
g : out STD_LOGIC;
f : out STD_LOGIC;
e : out STD_LOGIC;
d : out STD_LOGIC;
c : out STD_LOGIC;
b : out STD_LOGIC;
a : out STD_LOGIC);
end disp;
architecture Behavioral of disp is
type states is (s0, s1, s2, s3);
signal present_state, next_state: states;
signal outp: std_logic_vector (0 to 3);
signal counter: integer range 0 to 199999:=0;
signal tym: std_logic:='0';
signal clk_out: std_logic;
signal WY : std_logic_vector (6 downto 0);
signal WE : std_logic_vector (3 downto 0);
begin
--state machine
process (present_state)
begin
case present_state is
when s0 =>
outp <= "0111";
next_state <= s1;
when s1 =>
outp <= "1011";
next_state <= s2;
when s2 =>
outp <= "1101";
next_state <= s3;
when s3 =>
outp <= "1110";
next_state <= s0;
end case;
end process;
--frequency divider
process (clk_in)
begin
if (rising_edge(clk_in)) then
if (counter = 199999) then
tym <= not tym;
counter <= 0;
else
counter <= counter+1;
end if;
end if;
end process;
clk_out <= tym;
--state changing
process (clk_out)
begin
if (rising_edge(clk_out)) then
present_state <= next_state;
end if;
end process;
an1<=outp(0);
an2<=outp(1);
an3<=outp(2);
an4<=outp(3);
--set of bits for 7-segment display
WE <= an4 & an3 & an2 & an1;
with WE select
WY <= "1000000" when "0111", --display 0
"1111001" when "1011", --display 1
"0100100" when "1101", --display 2
"0000000" when "1110", --display 8
"1111111" when others; --display nothing
g <= WY(6);
f <= WY(5);
e <= WY(4);
d <= WY(3);
c <= WY(2);
b <= WY(1);
a <= WY(0);
end Behavioral;
I do something wrong with the with ... select instruction input, because Xilinx shows an error for the bolded line saying "Cannot read from 'out' object an4 ; use 'buffer' or 'inout'". How to solve this problem?
doesn't belong. Instead of declaring an1-an4 mode buffer you couldWE <= outp(3) & outp(2) & outp(1) & outp(0); -- WE <= an4 & an3 & an2 & an1;
. \$\endgroup\$
