I would like to design an LED driver circuit that allows for simultaneous analog and pwm control. That is, I would like to set the the LED current using an analog signal and then be able to switch using another pwm signal. I have a design with the analog control shown below. Is there a simple way to add the pwm control to this circuit?
I realize that there are numerous high level components that solve this problem but I am using this as a test case to learn basic electronics and would like to solve it using low level components.
