edit: solution found with our new board revision; outside of careless mistakes, buffering the signal with an op amp seems to have resolved the issue (as suggested by Joshua below).
I am working with a custom PCB using the ARM LPC2148. I'm trying to measure the battery voltage, which can be up to 4.2V or so, by using a voltage divider. However, using different resistors causes huge changes in the accuracy of ADC readings. Why is this?
Details:
I set the power supply to 3.0 V and hooked it up to an ADC pin, and got a reading of 2.987V, which is accurate enough for our use and shows that everything is working.
Using the voltage divider we built into the PCB with 47K and 100K resistors, the readings from the ADC vary in a non-linear manner -- I mean, not by a simple scalar factor -- (data below).
I built a voltage divider using 5% 10K 1K and 100K resistors (divides by 11 101), and took a reading on the ADC. Software showed 0.029V, or 0.319V after being scaled according to the voltage divider. This is obviously wrong, but the reason we're using large resistor values is that it limits the current draw; the power supply is showing less than 1mA being used.
I built another voltage divider using much smaller 5% resistors, of values 4.7 and 8.2 (divides by 2.745), and took a reading on the ADC. Software showed a value of 1.071V, or 2.940V after being scaled according to the voltage divider. This is obviously much better than the other voltage divider, and we could probably use this. However, the current draw is 228mA, which is unacceptable. It seems that the path forward is to redesign the board to use smaller resistor values and to hook the divider up to a transistor to limit current draw.
ADC Vref is 2.5V.
My question: why the huge change in accuracy from the different resistors?
Data:
power supply: voltage coming from the power supply to the board input voltage: voltage reading taken at the voltage divider voltage after divider: the voltage reading taken at the output of the voltage divider raw from ADC: value from the ADC; average of a few readings scaled by divider: value obtained by taking the ADC reading and scaling by the voltage divider (the first row is 0.28/0.32, etc) voltage divider: resistor values for the current data set +---------------+---------------+-----------------------+--------------+-------------------+-----------------+ | using the voltage divider on the board (47K / 47K + 100K) | | | | power supply | input voltage | voltage after divider | raw from ADC | scaled by divider | voltage divider | | 3.8 | 3.80 | 1.22 | 0.28 | 0.87 | 47,150 Ω | | 3.7 | 3.70 | 1.18 | 0.29 | 0.89 | 100,000 Ω | | 3.6 | 3.60 | 1.15 | 0.30 | 0.92 | 0.320 | | 3.5 | 3.50 | 1.12 | 0.31 | 0.95 | | | 3.4 | 3.40 | 1.09 | 0.32 | 1.00 | | | 3.3 | 3.30 | 1.06 | 0.33 | 1.04 | | | 3.2 | 3.20 | 1.02 | 0.35 | 1.08 | | | 3.1 | 3.10 | 0.99 | 0.37 | 1.15 | | | 3.0 | 3.00 | 0.96 | 0.39 | 1.21 | | +---------------+---------------+-----------------------+--------------+-------------------+-----------------+ | using an external voltage divider (4.7 / 4.7 + 8.2) | | | | power supply | input voltage | voltage after divider | raw from ADC | scaled by divider | voltage divider | | 3.8 | 3.79 | 1.39 | 1.37 | 3.76 | 4.7 Ω | | 3.7 | 3.69 | 1.35 | 1.33 | 3.66 | 8.2 Ω | | 3.6 | 3.59 | 1.31 | 1.30 | 3.56 | 0.364 | | 3.5 | 3.50 | 1.28 | 1.26 | 3.47 | | | 3.4 | 3.40 | 1.24 | 1.23 | 3.37 | | | 3.3 | 3.30 | 1.21 | 1.19 | 3.27 | | | 3.2 | 3.20 | 1.17 | 1.16 | 3.17 | | | 3.1 | 3.10 | 1.13 | 1.12 | 3.07 | | | 3.0 | 3.00 | 1.10 | 1.09 | 2.98 | | +---------------+---------------+-----------------------+--------------+-------------------+-----------------+ | using an external voltage divider (10K / 10K + 100K) | | | | power supply | input voltage | voltage after divider | raw from ADC | scaled by divider | voltage divider | | 3.8 | 3.80 | 0.35 | 0.35 | 3.81 | 9,820 Ω | | 3.7 | 3.70 | 0.34 | 0.34 | 3.71 | 98,400 Ω | | 3.6 | 3.60 | 0.33 | 0.33 | 3.63 | 0.091 | | 3.5 | 3.50 | 0.33 | 0.32 | 3.53 | | | 3.4 | 3.40 | 0.32 | 0.31 | 3.43 | | | 3.3 | 3.30 | 0.31 | 0.30 | 3.33 | | | 3.2 | 3.20 | 0.30 | 0.29 | 3.23 | | | 3.1 | 3.10 | 0.29 | 0.28 | 3.13 | | | 3.0 | 3.00 | 0.28 | 0.28 | 3.04 | | +---------------+---------------+-----------------------+--------------+-------------------+-----------------+
