Would this MOSFET would fine for driving things like a 9-12V DC motor?
Datasheet: http://www.jameco.com/Jameco/Products/ProdDS/1560173.pdf
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWould this MOSFET would fine for driving things like a 9-12V DC motor?
Direct gate drive by the controller probably won't work well, even if the controller has nominally 5 volt outputs, and if it has 3.3 volt outputs will definitely not work.
If you look at the second page of the data sheet, you'll see Vgs(th), the voltage necessary to turn on the FET, of 2 to 4 volts. Problem is, if you look closely you'll see that "on" means 250 uA, which is not likely a useful current to drive a motor with.
So you'll need some sort of level shifter between the controller and the FET. In many ways the easiest approach is to use a gate driver IC. I personally favor the Maxim 4426/4427 chips, but that's just habit. Go to any supplier and search on "gate driver".
If you have some NPN transistors handy, you can make something like
will do. Don't forget the diode, which should have the same current rating (or more) as the motor. If you don't include it, you risk killing the FET when you turn off the motor.
