I am just very confsed about how to do these sort of questions where they give you a point in the middle of two charges. The farthest I've gotten in questions relating to coulomb's law, is using the formula \$F = {kq_1q_2 \over d^2}\$ to work out one of the unknowns when given two variables. Can someone please explain how you would do a question like this:
Two point charges of charge -2 µC and -3 µC respectively are separated by a distance of 15 cm. Point X is positioned at an equal distance away from each of the charges.
a. Determine the net electric field at X.
b. Find the point of equilibrium between the charges.
