I am making a solar charger for 3 AA batteries. I have two 6 volt 100mah solar panels. Will it be more beneficial to connect them in parallel to have more current or in series to increase the voltage? The voltage of the 3 AAs will be at least 3.6 so I am wondering if there will be enough potential difference to charge them. I am aware that this charger will be slow and I will make sure that the batteries do not overcharge. They will probably be 1300mah 1.2 volt rechargeables. This is the solar panel: http://www.ebay.com/itm/301018398863?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  • \$\begingroup\$ I recommend using a solar panel based charger, as they account for variation in light to the panels vs. the charge current and voltage needed. A direct connection can overcharge the batteries and standard charger IC's do not account for a wide range of voltage inputs such as a solar cell array. \$\endgroup\$
    – user105652
    May 26, 2016 at 0:17
  • \$\begingroup\$ I plan on watching over the charging process and making sure that the batteries do not overcharge. Many instructables do it this way. I hope it works \$\endgroup\$
    – shurup
    May 26, 2016 at 1:22
(In this case) you're better off putting them in parallel - your batteries will not rise to 12V.
With the solar panels in series you will also have other issues. Imagine that one of the panels does not receive sunlight - it would generate a low current and the other panel would generate a high current - I do not think that the low current panel will be happy with the high current of the other one.
