I know the result is h12 = -h21, but it's strange since h12 = V1/V2 and h21 = I2/I1.
Reciprocity theorem says that ratio of excitation to result must remain same if they are interchanged, how do you arrive at that result from the statement?
  • \$\begingroup\$ What is the context? \$\endgroup\$ – Bradman175 May 28 '16 at 6:07
No, the reciprocity theorem does not say that. That is just the definition of reciprocity (actually, not well stated). The reciprocity theorem states, instead, that a certain specific class of networks, that of networks composed of resistors, inductors, capacitors, and transformers, is reciprocal.
First, let me start with a better definition of reciprocal network [1]:
A reciprocal network is one in which, for any pair of excitation and response points, here labeled 1 and 2, \$I_1 = I_2\$ if \$V_1 = V_2\$.
Notice that when you set a current excitation you should look at the voltage response and viceversa.
Consider now the hybrid representation of a two-port network,
$$ \begin{pmatrix} V_1 \\ I_2 \end{pmatrix} = \begin{pmatrix} h_{11} & h_{12} \\ h_{21} & h_{22} \end{pmatrix} \begin{pmatrix} I_1 \\ V_2 \end{pmatrix}.$$
Set, e.g, a current excitation at port 1, \$I_1 = I\$, and look at the open circuit voltage response at port 2, that is, find \$V_2\$ when \$I_1 = I\$ and \$I_2 = 0\$. Plugging these conditions into the matrix equation above, yields
$$ \begin{pmatrix} V_1 \\ 0 \end{pmatrix} = \begin{pmatrix} h_{11} & h_{12} \\ h_{21} & h_{22} \end{pmatrix} \begin{pmatrix} I \\ V_2 \end{pmatrix},$$
from which we obtain
$$V_2 = -\frac{h_{21}}{h_{22}}I.$$
Now exchange the position of the excitation and the response: set \$I_2 = I\$, \$I_1 = 0\$ and find \$V_1\$. From
$$ \begin{pmatrix} V_1 \\ I \end{pmatrix} = \begin{pmatrix} h_{11} & h_{12} \\ h_{21} & h_{22} \end{pmatrix} \begin{pmatrix} 0 \\ V_2 \end{pmatrix}$$
we get
$$V_1 = \frac{h_{12}}{h_{22}}I.$$
The reciprocity condition requires the two responses to be equal, \$V_1 = V_2\$, that is,
$$\frac{h_{12}}{h_{22}}I = -\frac{h_{21}}{h_{22}}I$$
from which \$h_{12} = -h_{21}\$.
[1] N. Balabanian, T. A. Bickart, Electrical network theory, John Wiley & Sons, Inc., 1969.
