I have two 6 volt 100mA solar panels. I have connected them in parallel and was expecting to see a maximum of 200ma when I short circuit it. As expected, I got 6 volts, but only 65ma. Does this always occur? The sun was really bright at that time.
    \$\begingroup\$ Why did you expect to see 200 mA into a short circuit? \$\endgroup\$
    – The Photon
    May 29, 2016 at 15:08
  • \$\begingroup\$ What short circuit current do you get? \$\endgroup\$ May 29, 2016 at 15:27
  • \$\begingroup\$ The OP mention 65mA into a short for both cells in parallel Olin. \$\endgroup\$
    – user105652
    May 29, 2016 at 15:34
  • \$\begingroup\$ I got 65ma when I short circuited it, but I expected 200ma because they are connected in parallel and the short circuit rating is 100ma. \$\endgroup\$
    – shurup
    May 29, 2016 at 15:40
  • \$\begingroup\$ @NickSolonko. Please read my answer. The 100mAh rating is for one hour of use as a battery charger. 100mAh is also a maximum possible current in the brightest light over one hour. The cells are NOT batteries and do not behave the same way when shorted. \$\endgroup\$
    – user105652
    May 29, 2016 at 15:44
100mAh means 100 milliamps for an hour at maximum possible brightness of the sun, not per an instance of a short. They are not batteries which can put substantial current into a short circuit. The 65mA reading you were getting is what the solar cells could put into a short circuit with the light you had.
Solar cells are actually photo-diodes and the current output is limited by how much light is hitting the diode and its efficiency in converting photon energy into excited electrons. They do NOT behave the same as a charged battery when shorted.
That is why solar cells used to charge batteries often have a charger IC designed to properly charge the batteries based on current sunlight conditions and the charging needs of the battery. Look up 'solar cell charger IC' on the web. They are cheap to buy and will prevent overcharging your batteries. They can also boost the charge current when the sunlight is low. If very low sunlight they stop charging.
Huge panels of solar cells that are over 2 meters sq are often fused and can be a shock hazard. The small ones you have pose no threat except possibly overcharging a small battery if a regulator is not used.
  • \$\begingroup\$ So when I attempt to charge batteries with my solar panels, will the current exceed 65ma? \$\endgroup\$
    – shurup
    May 29, 2016 at 15:47
  • \$\begingroup\$ That is possible, which is why solar cells used to charge batteries often have a charger IC designed to properly charge the batteries based on current sunlight conditions and the charging needs of the battery. Look up 'solar cell charger IC' on the web. They are cheap to buy and will prevent overcharging your batteries. They can also boost the charge current when the sunlight is low. If very low sunlight they stop charging. \$\endgroup\$
    – user105652
    May 29, 2016 at 15:52
  • \$\begingroup\$ It's not so much that the cell has "some resistance that limits the short-circuit current", as it is that solar cells are actually photo-diodes and the current output is limited by how much light is hitting the diode and its efficiency in converting photon energy into excited electrons. \$\endgroup\$ May 29, 2016 at 15:59
  • \$\begingroup\$ 100 mAh means 100 mA for an hour not per hour. \$\endgroup\$
    – The Photon
    May 29, 2016 at 16:02
  • \$\begingroup\$ @TomCarpenter. I was going to add some techno-stuff but the OP seems overloaded already. If it will help I can add that to my answer instead of using the term 'resistance'. \$\endgroup\$
    – user105652
6
The I-V (current-voltage) curve for a solar cell is a little complex. Below is an example of the relationship:
I-V Curve and different light levels
Image Source
What that basically says is that the more current you try to draw for a solar panel, the lower its terminal voltage will be. You get the maximum current at short circuit, and the maximum voltage at open circuit.
Solar cells are specified with two values - short circuit current (in your case 100mA), and open circuit voltage (in your case 6V). 100mA does not mean 100mAh, and the rating of the cell is definitely in mA not mAh (mAh would be completely meaningless for solar cells). You may be wondering why it is rated in terms of short-circuit current and open-circuit voltage, well using those two data points you can get a rough idea of the I-V curve for any given irradiance level.
So why do you not get 200mA short circuit current like you expect? Well, the cell generates current as light hits it and transfers energy to electrons which are then free to move as a current. As such it makes sense that higher the intensity of the light applied to the cell, the larger the output current can be. In other words, the short-circuit current is dependent on the light intensity. If you put the cell in a dark room, the short circuit current will be much lower.
You will be seeing only 65mA as you are probably operating at a lower light intensity than when your panel was characterised.
There is another thing to take away from the relationship. If you try and draw the maximum possible current from the cell, it won't actually give you any power - all of the power is dissipated internally over the cell (which is not good for it!). Conversely if you try to run the output at the highest possible voltage, you won't get any power either as there is no current (again the energy from the light source will simply be dissipated in the cell). To get the most power out, you need to operate somewhere around the corner of the I-V curve where the output power is maximal.
There are some good answers on EE.SE about using solar panels and a process called maximum power point tracking.
  • \$\begingroup\$ Thanks for the -1 downvote (-4) after the fact. I only wrote the details the OP wanted. If you want to give the OP a college level EE course in the subject for some points, have it your way. \$\endgroup\$
    – user105652
    May 29, 2016 at 17:55
  • \$\begingroup\$ @Sparky256 erm, get your facts straight, I didn't downvote your answer! \$\endgroup\$ May 29, 2016 at 17:59
  • \$\begingroup\$ My mistake then. I apologize for assuming it was you. But twice now I have had the OP's vote plus 2 up votes only to have a vote taken away within 2 hours. The last time my votes were restored in about 2 days, but I do not like the indecision or 'backstabbing' appearance of it all. Up votes should not be reversed once given. The voting process seems to be erratic. \$\endgroup\$
    – user105652
    May 29, 2016 at 20:18
