Here is an animation showing the problem in action :
https://gfycat.com/ImmaterialNextGermanshorthairedpointer
I press Play, it works, I stop and play again, it stops working until I remove the connections and plug them in again.
  • \$\begingroup\$ I see a sequence of statements but no question. \$\endgroup\$
    – user16324
    Commented May 30, 2016 at 11:31
  • \$\begingroup\$ Hmm, not much of a question, other than a "Why is this happening"? \$\endgroup\$
    – Zee
    Commented May 30, 2016 at 12:08
-1
Decrease the clock speed of the microcontroller, this solves in most cases.
  • \$\begingroup\$ This answer is valid. Some hosts may not have the bandwidth to perform analysis of Real-time analysis of complex or fast rise-time processes. \$\endgroup\$ Commented Dec 3, 2016 at 0:50
-2
Le problème est dû a cause de l'alimentation en courant continue additionnée (DC générateur) ou multiple tension de 5V.
Google translate says:
"The problem is due to the addition of DC power (DC generator) or multiple voltage of 5V."
    \$\begingroup\$ Welcome to EE.SE. All questions and answers on EE.SE should be strictly in English. \$\endgroup\$
    – Hazem
    Commented Jul 6, 2018 at 14:06
  • \$\begingroup\$ "est dû à cause" isn't even proper French... \$\endgroup\$
    – dim
    Commented Jul 6, 2018 at 14:21
