I'm having difficulty understand how this receiver works due to its size. It was taken from this site: http://jap.hu/electronic/rf.html. It is on top labled toy car receiver.
The toy car transmitter is easy enough to understand, and I suspect that the receiver is essentially working the same way, but backwards and with more filtering.
I need someone to break down the circuit into its components and explain in depth how it works.
Here it is: enter image description here
    \$\begingroup\$ I have no experience in RF except that I saw this circuit before and asked someone how it works. The first stage is tuned at 27,145 Mhz and will pickup the signal in this frequency. After that, it is all amplification and level translation or relay driving. Most of the designators are missing. I think people will have hard time explaining. \$\endgroup\$ – abdullah kahraman Dec 15 '11 at 6:13
  • \$\begingroup\$ @abdullahkahraman I figured out the 1st and 2nd stage (sort of) already. Could you explain the 3rd part in more detail. I don't understand what you mean by level translation. \$\endgroup\$ – sj755 Dec 15 '11 at 6:17
    \$\begingroup\$ I don't know in detail, too. That's why I commented on it. However, 680k and 2.2k and 10k are for biasing the 3rd transistor. 100n is for coupling. 1n is to have negative feedback in high frequencies thus, reducing the gain. I don't know what those diodes are for but one of them is probably a kickback diode. Maybe one of the diodes is to take negative feedback over lower 40n in only one direction. The upper 40n cap could be for high frequency current limiting. I am just thinking loudly, btw. That's why this is a comment. \$\endgroup\$ – abdullah kahraman Dec 15 '11 at 6:25
  • \$\begingroup\$ @abdullahkahraman And great comments like these is why I upvote. You have been greatly helpful. I'd appreciate any further input. I'll continue waiting for a complete answer though. \$\endgroup\$ – sj755 Dec 15 '11 at 7:22
    \$\begingroup\$ @abdullahkahraman OK, suit yourself. I still think you're more knowledgeable than you think. \$\endgroup\$ – sj755 Dec 15 '11 at 7:56
9
Annotated schematic
Blue stage: tuned RF amplifier; Orange stage: General purpose amplifier; Green stage: Relay driver;
Pink line: high current drive route on relay turned on.
On first stage
DC point is given by resistors, taking capacitors as open circuits and taking inductors as short circuits. On output dc bias is 6.1V and collector voltage dc point is 5.5V. Ic = 410uA aprox.
dc point simulation, transistor was replaced but its characteristics wont differ so much
Green marked network formed by C2, R3 and C6 is a low-pass filter for negative feedback. It stabilizes the gain loop and stretchs the natural bandwith of the transistor.
$---+--R3--+---$
    C2     C6
C4 is the antenna input AC coupling. L4 and C3 build a "tank circuit" or "resonant circuit": the heart of the tuned amplifier, It gives the typical [frequency response] of this amplifier. However, the final tuning frequency is given by the whole analysis of the stage because C5, C7, L1, and the low pass feedback filter affect AC performance too.
C5 is a bandwidth limiter and it acts on upper bound.
This stage is like a deformed common emitter modified to amplify only the right frequency (not the right RANGE of frquencies as on wide band amplifier).
On second stage
It acts as an general purpose amplifier or coupling impedance enhancer. It is a common emitter stage with R:220k and C:1nF network acting as negative feedback and biasing base voltage level.
On third stage
this is the high current sink driver. diodes network outside of the green boundary, is a no-ticking enhancer for the high frequency of the input signal. the input signal is oscillating, but relay cannot oscilate as fast as input signal. Diodes provide compensation on negative ringing, spiking currents.
Yellow boundary
relay load. It is a heavy inductive load for the transistor, therefore diodes network help it on good counter spikes routing.
Curious things
-All 100nF caps are to AC coupling one stage with next stage. Its value is high because it only want to skip DC bias, not set freq cutoff.
-output of first stage is not in colector pin, which place would give better voltage gain (maybe in that point have a great impact on output impedance?). I think that output between R1, R2 and C1 produces poor sensitivity.
-tank circuit is not annotated with exact values for 27MHz therefore you need calculate or experimentate.
-F1 means ferrite core.
