-1
I have this simple code which doesn't behave as it should and can't figure out why.
entity test is
port (D0        : in  std_logic;
        output      : out unsigned(6 downto 0));
end test;
architecture Behavioral of test is
    signal clk_Cent_i : unsigned(6 downto 0);
begin
    gen_clk : process (D0)
    begin
    if  D0 = '1' then
    clk_Cent_i<=clk_Cent_i + "1";
    end if;
    end process gen_clk;
output<= clk_Cent_i;
end Behavioral;
I want by pressing a button to increment a counter and show the counters' number to 7 leds.
If you want to count individual presses, you need to react on signal edges. So, instead of
if  D0 = '1' then
you need to write
if(rising_edge(D0)) then
Warning: this will only work if D0 is correctly debounced, i.e. a single rising edge is produced on each press.
    \$\begingroup\$ This will make D0 a clock signal. The switch will likely fail the timings. Better to set up an FSM to monitor the state of the switch on each clock edge. \$\endgroup\$ – user110971 May 30 '16 at 18:17
