What is the symbol that is below the C1 capacitor and R1 resistor. Is it the symbol of grounding?
4\$\begingroup\$ This question has little to recomend it - it doesn't seem that you did much work yourself to find an answer, and the answer is rather trivial. \$\endgroup\$– Sean HoulihaneMay 31, 2016 at 12:53
The symbol represents signal ground. This ground is often connected to the usual ground of a device, commonly known as "earth". However if a system is very sensitive the two grounds cannot simply be connected, but require a thorough engeneering approach and a good ground able to handle high currents.
More info on the grounding types:
https://en.wikipedia.org/wiki/Ground_(electricity)#Electronics
\$\begingroup\$ I think ground is usually represented using the vertical line connecting with a series of horizontal lines in a triangular shape symbol. Ground, 0V, earth and equipotential level may be synonymous in some circuits/applications but there are subtle or critical differences in others. \$\endgroup\$– TafTMay 31, 2016 at 16:28
\$\begingroup\$ The symbol shown is signal ground. The series of horizontal lines forming a triangular shape is circuit ground, and the horizontal line with vertical lines coming off of it (that looks like a fork) is earth ground. \$\endgroup\$ May 31, 2016 at 23:52
It means Equipotential level. Often used, in CAD, for analog ground or signal ground. See IEEE STANDARD 315-1975 - "IEEE Standard for Graphic Symbols for Electrical and Electronics Diagrams (Including Reference Designation Letters)"
Yes it is. Gound or zero potential depending on your application.
