I have schematic document with 15 sheets, when I anotate all the sheet it will modify all the sheets sometimes. I want to be able to save all the sheets in once without saving all of them one by one. How to do this ?
    \$\begingroup\$ Did you try File -> Save All or Project >> Design Workspace >> Save All? Did you read Altium Techdoc ? \$\endgroup\$ Jun 1, 2016 at 10:17
  • \$\begingroup\$ I read it but I went trough this seems like. I was used to save them all one by one clicking on each sheet. Thank you \$\endgroup\$
    – chris
    Jun 1, 2016 at 11:15
  • \$\begingroup\$ This is a horrible question. This, to me, is basic computer use. It's well established that if you want to save anything (in any program), its located under the File, if the toolbar is available. Sorry OP, but you should have known a lot better than this. \$\endgroup\$
    – efox29
    Jun 2, 2016 at 15:14
  • \$\begingroup\$ @efox29, don't reply if it is so horrible, we don't need trolling. \$\endgroup\$
    – chris
    Jun 2, 2016 at 16:26
To put it in an answer, there are two options to save all:
  1. File >> Save All
  2. Project >> Design Workspace >> Save All
After launching these commands, all open projects and documents will be saved.
