Assume I connect a microcontroller board (like an STM32F4) to a PC via USB. Is there anything in the USB communication protocol that contains host clock data? In other words, can I sync the microcontroller to the PC clock just by hooking up to USB?
If that's not possible, could you suggest some clever minimal-effort way to get the clock info from PC to the STM32F4?
I guess I could always write some software to run on the PC in the background and provide that info to the STM32F4, and I'll do that if I must, but I'd like to avoid that.
I could also use a network shield and have the STM32F4 query the PC over the network, but I'd like to keep cost and complexity down by not using any extra shields.
I could also have the STM32F4 run its own clock base, but that's not an option - it must be synced to this particular PC down to the second, even if the PC itself is out of sync with NTP.
By the way the Synchronisation is on the Microsecond level.
EDIT :
I found this for Arduino Board : http://playground.arduino.cc/Code/DateTime
