-2
For example, there are three values.
$$X_1 = \frac{1}{250\angle16.26^\circ} \quad X_2=\frac{1}{200\angle -36.87^\circ} \quad X_3=\frac{1}{50\angle -53.13^\circ}$$
Then, I want to calculate \$X_1+X_2+X_3\$.
I can solve this by the following process.
  1. Change \$X_1\$, \$X_2\$, and \$X_3\$ into the form of \$A+jB\$, resepctively.
  2. Add respective real part and imaginary part.
  3. Re change into the phasor form.
However, I trust that there exist another easy way to solve it rather than my process.
There is 2 way that I see you can resolve this.
  1. If you don't have acess to a calculator that can do complex number, well first you need to do the division. The easiest way to do that is to use polar notation. After that you transform each X into cartesian form to add them up.
  2. If you have access to do a calculator who can do complex number, just use the complex function of your calculator, you will save a lot of time.
