I am using my arduino to automatically change water of my aquarium. The program runs fine, the pumps, heaters and valves are controlled by relays. When connected to my laptop, I can see via the serial monitor it works and goes trough the program well. But now my LCD gives weird symbols after switching the relais on/off. I have read quite some questions and answers already about these problems, but no univocal clear answer.
My main question: Can the disturbance also come due to the 'physical' distance from the lcd to the relais?
Let me include the picture of my setup so far (still in testing phase, and I'm not that good at electronics, so maybe you're going to laugh about my setup:
As you can see, the arduino is right above the relais, next to a 24V DC power supply for the valves, and the switch-plugs are connected to the relays. The relays will switch 2 pumps (30W) but also a heating elements of 300W.
My question: Can the weird symbols only be caused by current trough wires like discussed in this topic? Or does the 'physical' distance also cause troubles?
Also: these relais I thought were Solid State Relais but probably are not, since the same webshop is selling 8-relay board named as Solid State Relais as well:p. might that give me a solution? Here a link to the schematic of the relays I'm using now: schematic. (Considering that since I saw this comment in the topic linked above):
Look at the datasheet for the "Relay". The input to the relay is actually driving a tiny SSR, which switches the actual power to the relay itself. Since the input to the relay thingie is a SSR input, I don't see a diode really doing anything
If anyone can help me with this problem would be great, I've already read quite a lot about these problems, but don't understand how to solve it. If it is fixable with capacitors, resistors or snubbers, please attach a little drawing with it if possible. Thanks for the time everyone!
