7
I was looking at Micrel AN-53 and I have noticed that in a circuit in the first page (circuit is below), at the output of an 400KHz, 27V, 7A, 180W boost converter, there are two 680 uF, two 10 uF and one 0.1 uF capacitor.
I can understand that 680uF capacitors are the bulk output capacitors and instead of 1360 uF, it is better to use 2x680 uF with the benefits of low ESR and rejection of higher frequencies than the ones rejected using 1360 uF.
I may understand that 10 uF is to smooth out even higher frequencies and they have much lower ESR than electrolytics.
However, I cannot understand why is 100nF capacitor is used? Load will use decoupling cap if needed. In addition to that, shouldn't the 100nF capacitor be placed very close to the supply and the ground to keep the lead inductance low? Won't the filtered signal get nasty on its way to the load? Using it in the output makes no sense but unnecessary and extra PCB area to me.
So, could you please explain the function and the need of 10uF and 100nF capacitors in the output (C3, C4, C10)?
Second question first -
  • 2 x 680 uF often will have a better ripple current rating than a single larger cap - sometimes very significantly so.
  • 2 x 680 uF also may be lower height or easier to fit in board space - MAY have more area but be less obstructive than a single larger cap.
  • Also, as you say, ESR may be better, but often a single large cap is as good.
The 0.1 uF capacitor is intended to remove very high frequency components better than the larger capacitors do.
The small capacitor will usually have have low ESR, low lead and internal inductance, a higher self resonant frequency and a lower overall impedance at higher frequencies. At least, that's the plan. Reputable manufacturers may publish tables showing impedance with frequency and from these an excessively keen [tm] designer can provide a filtering combination that produces a best overall result. It was traditional to consider a 0.1uF cap as the standard HF filter cap, but there have been two schools of thought to that in recent times.
One argument is that increasing frequencies of both SMPS and processors and target ICs make smaller caps better suited to the typical frequencies. The other holds that the new ceramic caps are far superior to those of, eg, a decade ago and that a 1uF or even a 10 uF ceramic will do a fine job at relevant frequencies. Both arguments have merit. If you use a 0.1 uF modern ceramic instead of going to a 1 uF then you arguably get the benefit of both arguments :-). (ie it's bigger than you might have used and smaller than you might have used).
I do not see at a quick read anything that says where that capacitor is physically located. While the caps are shown sequentially on the diagram, that is only an electrical diagram and actual layout is not strongly suggested by it. General component placement will often have some resemblance to circuit diagram flow, but nothing is necessarily fixed. In this case the 0.1uF can be physically near the cathode of D1 and the ground side of R2, R14, R16 and that is where I would try to locate it.
Cypress excellent - Using decoupling caps
How to select bypass caps Goodish
Tends to suggest that bigger is better mostly :-) :
From this excellent guide - A practical guide to high speed PCB layout
Useful and related but not 100% on topic here
Useful
Related - caps and ESR Wikipedia
  • \$\begingroup\$ So, does this 0.1uF modern ceramic help the controller IC in transients control or such improvements in its control? If so, how? If not, and if the load is not really close to that capacitor, why is it used where lead inductance make the cap useless? \$\endgroup\$ Dec 16, 2011 at 11:29
  • \$\begingroup\$ And why I can't cite your name in comments after '@' symbol? \$\endgroup\$ Dec 16, 2011 at 11:30
  • \$\begingroup\$ @abdullahkahraman - citing rules seemed to change a few days ago. If you post conmments on the question or answer of a person they get a copy automatically sl citing used to be redundant and now is impossible. \$\endgroup\$
    – Russell McMahon
    Dec 16, 2011 at 12:02
  • \$\begingroup\$ @abdullahkahraman I'd expect the biggest gain to be in very high frequency noise bypassing at or near source. The more track inductance between it and load the better for filtering. There may be some stability gain but this is usually liable to relate to the larger caps. | More important for stability is C12 which they have not git. It's on the cct diagram but explicitly excluded in the BOM. This cap can have a MAJOR effect on stability and performance. Ask me how I know :-). \$\endgroup\$
    – Russell McMahon
    Dec 16, 2011 at 12:08
