I have been working on a question which is: Design a synchronous up-counter that goes through the sequence 1 2 5 6 3 4 7 0 and then repeats. Implement the counter using D flip-flops.
So Far I have the managed to work out the following:
Is this correct?
Would it be correct to use this truth table instead of the previous one? enter image description here
  • \$\begingroup\$ Have you tried simulating it? \$\endgroup\$ – Tom Carpenter Jun 2 '16 at 15:58
    \$\begingroup\$ It's close though. Your Kanaugh maps are right, but one of your equations from one of the Karnaugh maps is wrong. I'll let you figure out which... \$\endgroup\$ – Tom Carpenter Jun 2 '16 at 16:08
    \$\begingroup\$ But for future reference, it is the job of your lecturer/teacher to mark your work, not us. \$\endgroup\$ – Tom Carpenter Jun 2 '16 at 16:09
    \$\begingroup\$ But to test it you can actually use some simulator. There are several pretty good ones and free. And easy to use. \$\endgroup\$ – Eugene Sh. Jun 2 '16 at 17:27
    \$\begingroup\$ +1, for once, a student not directly putting a scan of the problem statement without further research, that deserves an upvote. \$\endgroup\$ – dim Jun 2 '16 at 18:10
If your teacher asked to design this with only D flip flop , I don't know is it possible of not, But using 3 D flip flop and a 2 half adder (or 1 full adder) , you can easily design it. if you look closely , your LSB bit ( "C" ) just flipped in every clock cycle and AB is just the value of "AB+C" bits.
