Hi all, So the question for this circuit was: Using logic gates design a circuit which turns on a light if any one of a car's four doors are opened. Assume that each door is equipped with a switch which is open-circuit if the door is opened.
I do not understand why when a switch is closed, the current flows to ground. Can anyone explain this?
