I'm trying to connect AT89S8253 with Keil ULINK2. But the documentation is nil about 8051 controllers. As per the web, the pin connection is this. ref: http://www2.keil.com/coresight/coresight-connectors#10pin
ULINK2 pinout
ULINK2 supports the ATMEL family of 8051 controllers (reference: http://www.keil.com/dd/). ATMEL uses SPI pins for the ISP programming. What is the correct pin connection?
[Updated - Original question referred to AT89C8253, but OP has confirmed this was a typo and AT89S8253 was intended.]
  • \$\begingroup\$ (a) "I'm trying to connect AT89C8253 with Keil ULINK2" - Why exactly do you believe that the ULINK2 supports that specific chip? Please supply a link to a webpage which supports that claim. (b) "It supports the ATMEL family of controllers" - What is the "it" in your sentence? Atmel produce various different families of MCUs, so your claim that "it" supports all of them (no matter what "it" you are referring to) seems unlikely. || I think I understand your confusion, but before writing an answer, I want to make sure I understand where exactly you are reading those claims. \$\endgroup\$ – SamGibson Jun 4 '16 at 13:03
  • \$\begingroup\$ Edited as per your comments. \$\endgroup\$ – Basheer Jun 6 '16 at 4:10
    \$\begingroup\$ Your link seems to show that some of Keil's tools support some of Atmel's 8051 derivatives, but it does not seem to list the ULINK2 as a supported interface for them, rather it lists software tools from Keil and adapters from other vendors. \$\endgroup\$ – Chris Stratton Jun 6 '16 at 4:24
  • \$\begingroup\$ @Basheer - I realised (late into writing my answer), that you seem to have mentioned a strange (non-existing?) model number - AT89C8253. Although there were many AT89Cxx devices, the AT89C8253 does not appear as a genuine part number in any searches I have done. Therefore I have replied as if you had meant to list the AT89S8253 device. As Chris Stratton explained above (+1), being listed in the Keil Device Database just means that some Keil tools support some Atmel devices. The critical details are listed in the specific database entry for each device. \$\endgroup\$ – SamGibson Jun 6 '16 at 16:17
  • \$\begingroup\$ @samGibso Yes. That was a typo. I'm sorry \$\endgroup\$ – Basheer Jun 7 '16 at 10:13
TL;DR - Unfortunately you can't use the ULINK2 with the Atmel AT89S8253.
Unfortunately you have misunderstood what that webpage shows. The "Legacy Device List" (it used to be called "Device Database" until MDK5 was released) is described by Keil here where they say:
"The Device Database is a searchable database that contains information about the various microcontrollers supported by software development tools from Keil.
The online Device Database entry for each device explains which features are supported." [My emphasis]
Therefore you can see that having an entry in the old Device Database does not mean that the ULINK2 is supported by that device. It just means that some features of the Keil range of software development tools are supported by that device. You have to view the specific webpage for that device, to see which features (e.g. ULINK2) are supported.
The Device Database page for the Atmel AT89S8253 does not mention the ULINK2 at all. That lack of mentioning ULINK2 is telling you that ULINK2 is not supported with that target device (I will explain why below). Whereas the Keil CA51 compiler kit is supported on that device, since this is listed.
Compare that with, for example, the Device Database page for the NXP (Philips) P89LPC952 which specifically lists:
"JTAG Debuggers
ULINK2"
Here is why the ULINK2 is not compatible with the Atmel AT89S8253:
As you can see in the Atmel AT89S8253 datasheet from the Keil website, there is no mention of a JTAG (or SWD) interface on that IC. However as described here in the ULINK2 webpage discussing the initialisation sequence with 8051-type devices, the ULINK2 uses a JTAG (or SWD) interface with the target device:
ULINK2 start sequence with 8051-type devices
However the P89LPC952 datasheet from the Keil website (which I mentioned as an example of a different 8051-style device earlier) shows that it does have a JTAG-style (really SWD) debug interface:
NXP P89LPC952 datasheet - debugger interface
This explains why that device is compatible with the ULINK2 and why its listing in the Device Database does mention the ULINK2 (unlike the listing for the Atmel AT89S8253).
In summary: The Atmel AT89S8253 does not have the required JTAG/SWD debugger interface to connect to a ULINK2, and Keil do not claim that the ULINK2 is compatible with that target device. Some other 8051-type device do have a JTAG/SWD debugger interface e.g. the NXP (Philips) P89LPC952.
| improve this answer | |
