-1
I found this circuit in a textbook, but I'm having a difficult time calculating the total resistance here. I tried using the formula for parallel resistors with the 3 resistors the the upper left, and then add that to the most right resistors. This would give me the total resistance of the upper half of the circuit. I then used that resistance, and used the formula for parallel circuits with the lower portion, but that gave me an incorrect answer.
The solution is supposedly 10ohm / 11.
  • \$\begingroup\$ This is recognizable as an application of a delta /wye transformation \$\endgroup\$ – placeholder Jun 6 '16 at 9:38
  • \$\begingroup\$ @placeholder it can be done still simpler by series/parallel transformations. R is 1 ohm. \$\endgroup\$ – Roger C. Jun 6 '16 at 9:42
  • \$\begingroup\$ @RogerC. you're no fun ... ;) \$\endgroup\$ – placeholder Jun 6 '16 at 9:47
  • \$\begingroup\$ @placeholder ok, I got it ;-) \$\endgroup\$ – Roger C. Jun 6 '16 at 12:57
If R=1, your approach is correct.
  1. 1 // 2 = 23
  2. 23 + 1 = 53
  3. 53 // 2 = 1011
1.
2.
| improve this answer | |
