I have developed an embedded electronics system centered around the Arduino Due. In my application, I am controlling the force of the end effector of a rigid object using a DC motor. The feedback force sensor has a lot of dead-time and I am unable to get the performance I expect with a standard PID. I am now looking into model predictive control, however at first I will try to use a Smith predictor. To do this, we need to develop an internal model describing the system we have. I have never done this and I need some guidance on formulating a discrete model and implementing it in C++/Arduino.
So far, I developed a continuous-time model based off of input-output data using System Identification Toolbox in MATLAB. Then I performed appropriate discretization (zero-order hold) to get a discrete model, \$H(z)\$, in the z-domain. To implement this in C++/Arduino I believe I am supposed to perform the inverse z-transform to get \$h[n]\$. \$h[n]\$ is then written in a interrupt service routine (ISR) to get the model output.
For instance, my continuous model is:
$$H = \frac{1}{5s+10}$$
Using zero-order hold at 100 Hz, the discrete model is:
$$H_{zoh} = \frac{0.00198}{z-0.9802}$$
Sample time: 0.01 seconds
Using the z-transform table, the inverse \$h[n]\$ is:
$$h[n] = 0.00198 \cdot \mathcal{H}(n-1) \cdot 0.9802^{(n-1)}$$
So far, is what I have been doing on the right track? If so, how would I implement this in an ISR?
  • \$\begingroup\$ The problem is you have three fairly different types of questions here: is your control system proposal sound, how one implements a discrete time controller on a small MCU, and specifically what that looks like in Arduino-style code. \$\endgroup\$ Jun 6, 2016 at 17:37
  • \$\begingroup\$ @ChrisStratton Out of the three problems you interpreted, "How one implements a discrete time model* on a small MCU" is the most appropriate. I understand how to implement in Arduino-style code as well as verifying if the control system is viable. \$\endgroup\$ Jun 6, 2016 at 18:06
  • \$\begingroup\$ I don't get it, why inverse? If you want implement the function you just have to use recursive formula tha you'll find for FIR filter, you have 1st order. \$\endgroup\$ Jun 6, 2016 at 18:07
You can write your system as \$H(z)=\dfrac{B(z)}{A(z)}\$ the use a recursive formula for IIR filter where you have A and B coefficients. Before you have to change the form to have denominator like \$ A(z) = 1+a1\cdot z^{-1}+ a2\cdot z^{-2}+..\$ by multiplying your form
  • \$\begingroup\$ Thank you very much Marko. I will try to do this however I found it much easier to transform the transfer function into a state-space representation using MATLAB and implementing the state-space model into Arduino. MatrixMath is a great library for this! \$\endgroup\$ Jun 9, 2016 at 13:52
  • \$\begingroup\$ Above formula is the simplest form y=b0*input-a1*y; b0=-0.00198/0.9802, a1=-1/0.9802. \$\endgroup\$ Jun 9, 2016 at 15:31
